[PROJ] transformations with epoch
Even Rouault
even.rouault at spatialys.com
Tue Mar 24 06:55:53 PDT 2026
Le 24/03/2026 à 14:09, Lesparre, Jochem via PROJ a écrit :
> Hi
> Unfortunately, no one reacted to this question. I would be interested
> in an answer too, because I don’t understand the cs2cs behaviour either.
Not much to answer but filing tickets for detected inconsistencies and
express the wished behavior
> Even worse: I don’t understand how there can be a different epoch for
> source and target CRS without specifying a velocity vector for the
> point of interest (like
> https://www.epncb.oma.be/_productsservices/coord_trans/) or a
> deformation grid model.
PROJ general philosophy when inferring transformation pipelines is to be
lax, and do its best, and ignore stuff that it can't make sense, unless
instructed otherwise (also we'd probably need a flag to make it error
out when time info not being used).
For CRS like Canadian NAD83(CSRS), doing NAD83(CSRS v7)@XXXX to
NAD83(CSRS v7)@YYYY will definitely use their velocity model. PROJ has
no concept of velocity vector per input point.
Even
> Jochem
> *From:*PROJ <proj-bounces at lists.osgeo.org> *On Behalf Of *Javier
> Jimenez Shaw via PROJ
> *Sent:* zaterdag 14 maart 2026 23:53
> *To:* proj <PROJ at lists.osgeo.org>
> *Subject:* [PROJ] transformations with epoch
> Hi
> I have been playing with epochs today. Maybe I am understanding
> something wrongly, but the outputs are very strange.
> My deductions are:
> - the 4th dimension (v_4) from the input is just copied into the
> output of cs2cs. Independently of epoch flags.
> - if --s_epoch or --t_epoch are set, the input v_4 is ignored (but
> still printed in the output)
> - if only --s_epoch or --t_epoch is set, v_4 is set before and after
> the transformation to that value
> - if both are set, v_4 is set to s_epoch before transforming, and to
> t_epoch after. So in this case t_epoch only works to tag the output
> time,... but it is not displayed in cs2cs (it is in the C function)
> Is that correct? Why is t_epoch overwriting the input time/epoch? Why
> is s_epoch setting the output time/epoch?
> In addition, cs2cs is apparently not printing the modified output
> epoch. This is not what C function does.
> Here are some transformations using the input epoch in the coordinates
> and the --s_epoch and --t_epoch
> echo 40 0 0 | ./cs2cs ITRF90 ITRF2014 -d 9
> 40.000000788 -0.000000207 0.009684166
> echo 40 0 0 foo bar | ./cs2cs ITRF90 ITRF2014 -d 9
> 40.000000788 -0.000000207 0.009684166 foo bar
> echo 40 0 0 2010 | ./cs2cs ITRF90 ITRF2014 -d 9
> 40.000000788 -0.000000207 0.009684166 2010
> echo 40 0 0 1980 | ./cs2cs ITRF90 ITRF2014 -d 9
> 40.000000087 -0.000000216 -0.028724159 1980
> echo 40 0 0 1980 | ./cs2cs ITRF90 ITRF2014 -d 9 --s_epoch 2000
> 40.000000555 -0.000000210 -0.003118609 1980
> echo 40 0 0 1980 | ./cs2cs ITRF90 ITRF2014 -d 9 --s_epoch 2010
> 40.000000788 -0.000000207 0.009684166 1980
> --t_epoch 2030
> --t_epoch 2030
> echo 40 0 0 1980 | ./cs2cs ITRF90 ITRF2014 -d 9 --t_epoch 2010
> echo 40 0 0 1980 | ./cs2cs ITRF90 ITRF2014 -d 9 --t_epoch 2030
> 40.000001256 -0.000000201 0.035289716 1980
> The pipelines for some cases are
> without setting --s_epoch or --t_epoch
> +proj=pipeline
> +step +proj=axisswap +order=2,1
> +step +proj=unitconvert +xy_in=deg +z_in=m +xy_out=rad +z_out=m
> +step +proj=cart +ellps=GRS80
> +step +proj=helmert +x=-0.0254 +y=-0.0115 +z=0.0928 +rx=0 +ry=0
> +rz=-0.00026
> +s=-0.00479 +dx=-0.0001 +dy=0.0005 +dz=0.0033 +drx=0 +dry=0
> +drz=-2e-05
> +ds=-0.00012 +t_epoch=2010 +convention=position_vector
> +step +inv +proj=cart +ellps=GRS80
> +step +proj=unitconvert +xy_in=rad +z_in=m +xy_out=deg +z_out=m
> setting --s_epoch to 2000
> +proj=pipeline
> +step +proj=set +v_4=2000
> +rz=-0.00026
> +drz=-2e-05
> setting --t_epoch to 2030
> +proj=pipeline
> +step +proj=set +v_4=2030
> +rz=-0.00026
> +drz=-2e-05
> setting --s_epoch to 2000 and --t_epoch to 2030
> +proj=pipeline
> +rz=-0.00026
> +drz=-2e-05
> PS https://jjimenezshaw.github.io/wasm-proj/transform.html is in this
> case probably showing better the output of the C function.
> Disclaimer:
> De inhoud van deze e-mail is vertrouwelijk en uitsluitend bestemd voor
> de geadresseerde(n).
> Gebruik, openbaarmaking, vermenigvuldiging, verspreiding en/of
> verstrekking van deze informatie aan derden is niet toegestaan.
> Op al onze producten en diensten zijn onze algemene
> leveringsvoorwaarden van toepassing
> [https://www.kadaster.nl/algemene-leveringsvoorwaarden].
> Disclaimer:
> This email and any files transmitted with it are confidential and
> intended solely for the use of the individual or entity to whom they
> are addressed.
> If you are not the intended recipient, you are notified that
> disclosing, copying, distributing or taking any action in reliance on
> the contents of this information is strictly prohibited.
> Our general terms and conditions of delivery apply to all our products
> and services
> [https://www.kadaster.com/general-terms-and-conditions].
> PROJ mailing list
> https://lists.osgeo.org/mailman/listinfo/proj
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20260324/37c2d39b/attachment-0001.htm>
More information about the PROJ
