[PROJ] Adding SAR related projection systems
Piyush Agram
piyush.agram at alumni.stanford.edu
Wed Nov 11 13:14:01 PST 2026
I would like to propose adding a SAR related projection system to the PROJ
system. I have an open PR for it here:
https://github.com/OSGeo/PROJ/pull/4922
I had also contributed to the Spheric-Cross Track-Height (SCH) system a few
years ago. With these projection systems, we would be able to represent the
imaging geometry of some SICD SAR imagery like in open datasets from
Capella and Umbra using a geotransform and the rrdot system. This system
can also be used for representing the geometry of one-line of Level-1 SAR
data from Sentinel-1 / NISAR / other SAR missions. These other missions use
a time-dependent projection system and we would need an orbit interpolation
mechanism in PROJ - complicating things. However, with the satellite
position for one line, this rrdot system can still be used.
Happy to answer any additional questions on the PR. This was purely
hand-coded and reference implementations exist in the public NISAR code
base.
Thanks
Piyush
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20261111/8891ca70/attachment.htm>
More information about the PROJ
