[PROJ] Adding SAR related projection systems
Kristian Evers
kristian at evers.dev
Thu Nov 12 01:55:06 PST 2026
Piyush,
Thanks for reaching out to the mailing list. As you may have gathered from the number of open pull requests we are quite overwhelmed at the moment. With a very active contributor having stepped down recently and a flood of LLM-powered pull requests we are trying to find our feet. Unfortunately that results in most pull request being put on hold at the moment. Work is being done behind the scenes to fix this.
So, stay tuned. Someone will get to your pull request. On the surface it looks like quality work. I suspect the SAR field is foreign to most of us, so reviewing your contribution requires more effort than usual. You can help us by providing more context, figures and examples in the docs. The ~70 page paper you refer to is a bit of a mouthful to read before starting reviewing the code. At the moment I feel like I need to be an expert in your field to understand your PR - try to lower that barrier.
/Kristian
On Wednesday, November 11th, 2026 at 22:14, Piyush Agram via PROJ <proj at lists.osgeo.org> wrote:
> Hi,
> I would like to propose adding a SAR related projection system to the PROJ system. I have an open PR for it here: https://github.com/OSGeo/PROJ/pull/4922
> I had also contributed to the Spheric-Cross Track-Height (SCH) system a few years ago. With these projection systems, we would be able to represent the imaging geometry of some SICD SAR imagery like in open datasets from Capella and Umbra using a geotransform and the rrdot system. This system can also be used for representing the geometry of one-line of Level-1 SAR data from Sentinel-1 / NISAR / other SAR missions. These other missions use a time-dependent projection system and we would need an orbit interpolation mechanism in PROJ - complicating things. However, with the satellite position for one line, this rrdot system can still be used.
> Happy to answer any additional questions on the PR. This was purely hand-coded and reference implementations exist in the public NISAR code base.
> Thanks
> Piyush
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20261112/eefc9bc4/attachment.htm>
More information about the PROJ
