[PROJ] network problems with docker in CI
Javier Jimenez Shaw
j1 at jimenezshaw.com
Fri Nov 13 08:48:19 PST 2026
Hi
There is a test that is recently failing in CI: linux_gcc_32bit
the problem is "Could not resolve host: cdn.proj.org"
like in
https://github.com/OSGeo/PROJ/actions/runs/43088112219
After some research, it seems to be that github is now moving to use ubuntu
26.04 for "ubuntu-latest". And somehow that is the root of the problem.
I can force the usage of ubunut-24.04. But maybe somebody with more
knowledge of docker can figure out how to fix it in a way that will not
fail when we have to move to 26.04
This is its configuration file
https://github.com/OSGeo/PROJ/blob/master/.github/workflows/linux_gcc_32bit.yml
Thank you
Javier.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20261113/7edf5ab5/attachment.htm>
More information about the PROJ
