[PROJ] network problems with docker in CI
Laurențiu Nicola lnicola at dend.ro
Sat Nov 14 01:55:08 PST 2026
Hi Javier,
This is a bug [1] in the Docker version installed GitHub Actions runner image. You can work around it by downgrading the runner image (which makes little difference given that the tests already run inside an Ubuntu 24.04 container), or by updating Docker [2]. You can also wait for a couple of days or weeks, as they update the images periodically.
Laurentiu
[1]: https://github.com/actions/runner-images/issues/14790
[2]: https://github.com/OSGeo/PROJ/pull/4946
On Fri, Nov 13, 2026, at 18:48, Javier Jimenez Shaw via PROJ wrote:
> Hi
> There is a test that is recently failing in CI: linux_gcc_32bit
> the problem is "Could not resolve host: cdn.proj.org"
> like in
> https://github.com/OSGeo/PROJ/actions/runs/43088112219
> After some research, it seems to be that github is now moving to use ubuntu 26.04 for "ubuntu-latest". And somehow that is the root of the problem.
> I can force the usage of ubunut-24.04. But maybe somebody with more knowledge of docker can figure out how to fix it in a way that will not fail when we have to move to 26.04
> This is its configuration file
> https://github.com/OSGeo/PROJ/blob/master/.github/workflows/linux_gcc_32bit.yml
> Thank you
> Javier.
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20261114/e95757d2/attachment-0001.htm>
More information about the PROJ mailing list
