[PROJ] network problems with docker in CI
Javier Jimenez Shaw j1 at jimenezshaw.com
Sat Nov 14 02:09:13 PST 2026
Thank you!
On Sat, 14 Nov 2026 at 11:01, Laurențiu Nicola via PROJ <
proj at lists.osgeo.org> wrote:
> Hi Javier,
> This is a bug [1] in the Docker version installed GitHub Actions runner
> image. You can work around it by downgrading the runner image (which makes
> little difference given that the tests already run inside an Ubuntu 24.04
> container), or by updating Docker [2]. You can also wait for a couple of
> days or weeks, as they update the images periodically.
> Laurentiu
> [1]: https://github.com/actions/runner-images/issues/14790
> [2]: https://github.com/OSGeo/PROJ/pull/4946
> On Fri, Nov 13, 2026, at 18:48, Javier Jimenez Shaw via PROJ wrote:
> Hi
> There is a test that is recently failing in CI: linux_gcc_32bit
> the problem is "Could not resolve host: cdn.proj.org"
> like in
> https://github.com/OSGeo/PROJ/actions/runs/43088112219
> After some research, it seems to be that github is now moving to use
> ubuntu 26.04 for "ubuntu-latest". And somehow that is the root of the
> problem.
> I can force the usage of ubunut-24.04. But maybe somebody with more
> knowledge of docker can figure out how to fix it in a way that will not
> fail when we have to move to 26.04
> This is its configuration file
> https://github.com/OSGeo/PROJ/blob/master/.github/workflows/linux_gcc_32bit.yml
> Thank you
> Javier.
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
> PROJ mailing list
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20261114/a9593a75/attachment.htm>
More information about the PROJ mailing list
