[pycsw-devel] CSW 2.0.2 - APISO 1.0 Implementation
Tom Kralidis tomkralidis at hotmail.com
Mon Apr 4 09:16:52 EDT 2011
Hi Angelos: For me, I would stay away from XSLT (heavy) and try to do this in Python proper for now.
..Tom
> Date: Sun, 3 Apr 2011 01:58:08 +0300
> From: gcpp.kalxas at gmail.com
> To: tomkralidis at hotmail.com
> CC: pycsw-devel at lists.sourceforge.net
> Subject: Re: [pycsw-devel] CSW 2.0.2 - APISO 1.0 Implementation
> I had an idea about the ISO to CSW core mapping.
> Perhaps we could make it with on-the-fly transformation using XSLT
> files... What do you think?
> Angelos
> On 03/31/2011 05:45 PM, Angelos Tzotsos wrote:
> > Hi Tom,
> > I am working now on database metadata import and validation.
> > I plan to add some code in owslib for inspire profile of metadata. My
> > intention is to include this extra code within the iso module and not
> > as a separate module.
> > Also I will look into the validation issue with schematron
> > After having some sample data in the db, I think we can continue with
> > the apiso testing, to see what is further needed.
> > Angelos
> > On 03/30/2011 11:44 PM, Tom Kralidis wrote:
> >> Thanks Angelos. FYI we will start to roll this into trunk in the
> >> next month or so. I've started a profile dev documentation page at
> >> http://sourceforge.net/apps/trac/pycsw/wiki/ProfileSupport to get
> >> high level ideas (most of which come from your sandbox).
> >> ..Tom
> >> Date: Wed, 30 Mar 2011 04:07:08 +0300
> >> To: pycsw-devel at lists.sourceforge.net
> >> Hi,
> >> Right now the ISO profile is being developed as a plugin.
> >> It can be enabled by the main configuration file and it also have
> >> its own configuration file to hold specific information.
> >> I am trying to insert few lines of code in the core DC model, and
> >> the profile code will have to implement some specific functions to
> >> plug in to the core (eg Extended Capabilities).
> >> There is only one major chunk of code in the core model, which
> >> involves the get_profile() function. We probably have to move this
> >> code in the future...
> >> Also in the sandbox, there is some initial work for INSPIRE.
> >> Regards,
> >> Angelos
> >> On 03/28/2011 04:41 PM, Tom Kralidis wrote:
> >> .ExternalClass .ecxhmmessage P
> >> {padding:0px;}
> >> .ExternalClass body.ecxhmmessage
> >> {font-size:10pt;font-family:Tahoma;}
> >> We want to extend the current model by adding the ISO specifics
> >> via profile. We should also consider the DC model as
> >> "default". Any profile will have to map back to the core DC
> >> model core
> >> queryables.
> >> Once the profile is loaded, then the CSW request processing
> >> continues like any other request. For each profile found, the
> >> model is extended (probably in CSW init).
> >> ..Tom
> >> Angelos Tzotsos
> >> Remote Sensing Laboratory
> >> National Technical University of Athens
> >> http://users.ntua.gr/tzotsos
> >> Enable your software for Intel(R) Active Management Technology to
> >> meet the
> >> growing manageability and security demands of your customers. Businesses
> >> are taking advantage of Intel(R) vPro (TM) technology - will your
> >> software
> >> be a part of the solution? Download the Intel(R) Manageability Checker
> >> today! http://p.sf.net/sfu/intel-dev2devmar
> >> _______________________________________________
> >> pycsw-devel mailing list
> >> https://lists.sourceforge.net/lists/listinfo/pycsw-devel
> Angelos Tzotsos
More information about the Pycsw-devel mailing list
