[pycsw-devel] About "GetRecords-filter-bbox Request"
Junichi Nagai
Nagai.Junichi at imslab.co.jp
Wed Jul 20 22:13:24 EDT 2011
Dear Tom Kralidis,
I'm Junichi Nagai from Japan.
(I'm sorry I can't speak English very well.)
I have a question about "GetRecords-filter-bbox Request" of pycsw.
I installed pycsw 1.0.0(http://sourceforge.net/projects/pycsw/files/1.0.0/)
to my OS:Windows.
I created the necessary tables and values for the repository by using
"./sbin/setup_db.py".
I imported all *.xml records(pycsw samples) by using
"./sbin/load_records.py".
(1)
I sent "GetRecords-all Request" to my pycsw
server(http://localhost/cgi-bin/pycsw/csw.py) at
"http://localhost/tester/index.html".
I got collect response from my pycsw
(attachment file:GetAll_Request_Response.jpg)
No problem.
(2)
I sent "GetRecords-Element Request" to my pycsw server.
I got collect response.
(attachment file:GetRecords-Element_Request_Response.jpg)
No problem.
(3)
I sent "GetRecords-filter-bbox Request" to my pycsw server.
I couldn't got collect response.
(attachment file:GetRecords-filter-bbox_Request_Response.jpg)
I got below error.
<ows:ExceptionText>Invalid query: (OperationalError) no such function:
query_spatial u"SELECT records.identifier AS records_identifier,
records.typename AS records_typename, records.schema AS records_schema,
records.bbox AS records_bbox, records.xml AS records_xml, records.source AS
records_source, records.insert_date AS records_insert_date \nFROM records
\nWHERE records.typename IN (?) AND query_spatial(bbox,'POLYGON((-5.00
47.00, -5.00 55.00, 20.00 55.00, 20.00 47.00, -5.00 47.00))','bbox','false')
= 'true'" ('csw:Record',)</ows:ExceptionText>
I sent oher "GetRecords-filter-*** Request" to my pycsw server.
I got same error.
Could you tell me what's wrong?
I use below.
OS:Windows XP
Python:Version 2.7
Database:SQLite3
Type: image/jpeg
Desc: not available
Url : http://lists.osgeo.org/pipermail/pycsw-devel/attachments/20110721/2fe4b7e9/GetAll_Request_Response.jpg
Type: image/jpeg
Desc: not available
Url : http://lists.osgeo.org/pipermail/pycsw-devel/attachments/20110721/2fe4b7e9/GetRecords-Element_Request_Response.jpg
Type: image/jpeg
Desc: not available
Url : http://lists.osgeo.org/pipermail/pycsw-devel/attachments/20110721/2fe4b7e9/GetRecords-filter-bbox_Request_Response.jpg
More information about the Pycsw-devel
