[pycsw-devel] AttributeError: 'module' object has no attribute 'get_config'
Tom Kralidis tomkralidis at hotmail.com
Fri Jul 22 12:34:22 EDT 2011
Hi: thanks for the info.  Do you have multiple Python installations on your machine?  Make sure the Python that PostgreSQL uses for plpython functions is the same used for pycsw itself (and it has lxml installed).
..Tom
> From: Nagai.Junichi at imslab.co.jp
> To: pycsw-devel at lists.sourceforge.net
> Date: Fri, 22 Jul 2011 12:45:58 +0900
> Subject: Re: [pycsw-devel] AttributeError: 'module' object has no attribute 'get_config'
> Dear Tom Kralidis,
> I'm Junichi Nagai.
> Thank you for updating configuration parsing.
> It works about creating the necessary tables and values for the repository.
> But I got another problem.
> (different from [pycsw-devel] About "GetRecords-filter-bbox Request")
> I imported all *.xml records(pycsw samples) by using
> "./sbin/load_records.py".
> (1)
> I sent "GetRecords-all Request" to my pycsw
> server(http://localhost/cgi-bin/pycsw/csw.py) at
> "http://localhost/tester/index.html".
> I got collect response from my pycsw
> No problem.
> (2)
> I sent "GetRecords-Element Request" to my pycsw server.
> I got collect response.
> No problem.
> (3)
> I sent "GetRecords-filter-bbox Request" to my pycsw server.
> I couldn't got collect response.
> I got below error.
> <ows:Exception locator="constraint" exceptionCode="InvalidParameterValue">
> <ows:ExceptionText>Invalid query: (InternalError) plpython: function
> "query_spatial" failed
> DETAIL: &lt;type 'exceptions.ImportError'&gt;: No module named lxml
> "SELECT records.identifier AS records_identifier, records.typename AS
> records_typename, records.schema AS records_schema, records.bbox AS
> records_bbox, records.xml AS records_xml, records.source AS records_source,
> records.insert_date AS records_insert_date \nFROM records \nWHERE
> records.typename IN (%(typename_1)s) AND query_spatial(bbox,'POLYGON((-5.00
> 47.00, -5.00 55.00, 20.00 55.00, 20.00 47.00, -5.00 47.00))','bbox','false')
> = 'true'" {'typename_1': 'csw:Record'}</ows:ExceptionText>
> </ows:Exception>
> I have installed "lxml version 2.3".
> It works for (1),(2).
> I think that "FUNCTION_QUERY_SPATIAL" of database don't know where "lxml"
> is.
> Could you tell me what's wrong?
> I use below.
> pycsw:version1.0.0(http://sourceforge.net/projects/pycsw/files/1.0.0/)
> OS:Windows XP
> Python:Version 2.7
> Database:postgres8.3
> lxml:version 2.3
> 10 Tips for Better Web Security
> Learn 10 ways to better secure your business today. Topics covered include:
> Web security, SSL, hacker attacks & Denial of Service (DoS), private keys,
> security Microsoft Exchange, secure Instant Messaging, and much more.
> http://www.accelacomm.com/jaw/sfnl/114/51426210/
> pycsw-devel mailing list
> https://lists.sourceforge.net/lists/listinfo/pycsw-devel
More information about the Pycsw-devel mailing list
