[pycsw-devel] Constraint parameter
Adrià Mercader amercader.dev at gmail.com
Fri Jun 3 09:43:54 EDT 2011
Hi all,
I'm using the latest svn trunk, and when doing a GetRecords query like
the following I get a 500 error with the following traceback:
http://localhost/csw/csw.py?REQUEST=GetRecords&SERVICE=CSW&VERSION=2.0.2&CONSTRAINTLANGUAGE=CQL_TEXT&TYPENAMES=csw:Record&RESULTTYPE=results&OUTPUTSCHEMA=http://www.isotc211.org/2005/gmd&CONSTRAINT_LANGUAGE_VERSION=1.1.0&ELEMENTSETNAME=brief
  File "/var/www/apps/pycsw/trunk/csw.py", line 40, in <module>
    CSW.dispatch()
  File "/var/www/apps/pycsw/trunk/server/server.py", line 243, in dispatch
    self.response = self.getrecords()
  File "/var/www/apps/pycsw/trunk/server/server.py", line 834, in getrecords
    (self.kvp['constraint'], self.kvp['sortby'], self.kvp['typenames']))
KeyError: 'constraint'
If I add something like "&CONSTRAINT=1" to the query I get the
records. AFAIK, constraint is an optional parameter of the getrecords
request, so maybe this is a bug?
Cheers,
Adrià
Adrià Mercader
http://amercader.net
More information about the Pycsw-devel mailing list
