[pycsw-devel] Constraint parameter
Tom Kralidis
tomkralidis at hotmail.com
Fri Jun 3 10:13:07 EDT 2011
> Date: Fri, 3 Jun 2011 14:43:54 +0100
> From: amercader.dev at gmail.com
> To: pycsw-devel at lists.sourceforge.net
> Subject: [pycsw-devel] Constraint parameter
> Hi all,
> I'm using the latest svn trunk, and when doing a GetRecords query like
> the following I get a 500 error with the following traceback:
> http://localhost/csw/csw.py?REQUEST=GetRecords&SERVICE=CSW&VERSION=2.0.2&CONSTRAINTLANGUAGE=CQL_TEXT&TYPENAMES=csw:Record&RESULTTYPE=results&OUTPUTSCHEMA=http://www.isotc211.org/2005/gmd&CONSTRAINT_LANGUAGE_VERSION=1.1.0&ELEMENTSETNAME=brief
> Traceback (most recent call last):
> File "/var/www/apps/pycsw/trunk/csw.py", line 40, in <module>
> CSW.dispatch()
> File "/var/www/apps/pycsw/trunk/server/server.py", line 243, in dispatch
> self.response = self.getrecords()
> File "/var/www/apps/pycsw/trunk/server/server.py", line 834, in getrecords
> (self.kvp['constraint'], self.kvp['sortby'], self.kvp['typenames']))
> KeyError: 'constraint'
> If I add something like "&CONSTRAINT=1" to the query I get the
> records. AFAIK, constraint is an optional parameter of the getrecords
> request, so maybe this is a bug?
> Cheers,
> Adrià
Hi Adrià: thanks for the info. I've applied a fix in trunk. Can you test and let me know if this works for you?
..Tom
URL: http://lists.osgeo.org/pipermail/pycsw-devel/attachments/20110603/c7d87132/attachment.html
More information about the Pycsw-devel
