[pycsw-devel] Constraint parameter
Adrià Mercader amercader.dev at gmail.com
Fri Jun 3 10:42:58 EDT 2011
Hi Tom,
Yes, that worked nicely thank you. But I'm getting another error :)
I loaded the example records provided in the data/cite directory (I'm
using Postgres 8.4 as db backend) and when doing this query:
http://localhost/csw/csw.py?REQUEST=GetRecords&SERVICE=CSW&VERSION=2.0.2&CONSTRAINTLANGUAGE=CQL_TEXT&TYPENAMES=csw:Record&RESULTTYPE=results&OUTPUTSCHEMA=http://www.isotc211.org/2005/gmd&CONSTRAINT_LANGUAGE_VERSION=1.1.0&elementSetName=summary
I get this:
 File "/var/www/apps/pycsw/trunk/csw.py", line 40, in <module>
   CSW.dispatch()
 File "/var/www/apps/pycsw/trunk/server/server.py", line 243, in dispatch
   self.response = self.getrecords()
 File "/var/www/apps/pycsw/trunk/server/server.py", line 926, in getrecords
   self.repository.queryables['_all']))
 File "/var/www/apps/pycsw/trunk/server/profiles/apiso/apiso.py",
line 375, in write_record
   codeSpace = CODESPACE).text = val
 File "lxml.etree.pyx", line 2437, in lxml.etree.SubElement
(src/lxml/lxml.etree.c:47709)
 File "apihelpers.pxi", line 210, in lxml.etree._makeSubElement
(src/lxml/lxml.etree.c:11413)
 File "apihelpers.pxi", line 205, in lxml.etree._makeSubElement
(src/lxml/lxml.etree.c:11349)
 File "apihelpers.pxi", line 283, in lxml.etree._initNodeAttributes
(src/lxml/lxml.etree.c:12184)
 File "apihelpers.pxi", line 1293, in lxml.etree._utf8
(src/lxml/lxml.etree.c:20190)
TypeError: Argument must be string or unicode.
val is None in apiso.py. If I check for val in line 371, the records
are returned nicely. (Of course I don't know the implications of this
fix)
Thanks,
Adrià
On 3 June 2011 15:13, Tom Kralidis <tomkralidis at hotmail.com> wrote:
>> Date: Fri, 3 Jun 2011 14:43:54 +0100
>> From: amercader.dev at gmail.com
>> To: pycsw-devel at lists.sourceforge.net
>> Subject: [pycsw-devel] Constraint parameter
>> Hi all,
>> I'm using the latest svn trunk, and when doing a GetRecords query like
>> the following I get a 500 error with the following traceback:
>> http://localhost/csw/csw.py?REQUEST=GetRecords&SERVICE=CSW&VERSION=2.0.2&CONSTRAINTLANGUAGE=CQL_TEXT&TYPENAMES=csw:Record&RESULTTYPE=results&OUTPUTSCHEMA=http://www.isotc211.org/2005/gmd&CONSTRAINT_LANGUAGE_VERSION=1.1.0&ELEMENTSETNAME=brief
>> CSW.dispatch()
>> File "/var/www/apps/pycsw/trunk/server/server.py", line 834, in getrecords
>> (self.kvp['constraint'], self.kvp['sortby'], self.kvp['typenames']))
>> KeyError: 'constraint'
>> If I add something like "&CONSTRAINT=1" to the query I get the
>> records. AFAIK, constraint is an optional parameter of the getrecords
>> request, so maybe this is a bug?
>> Cheers,
>> Adrià
> Hi Adrià: thanks for the info.  I've applied a fix in trunk.  Can you test
> and let me know if this works for you?
> ..Tom
Adrià Mercader
http://amercader.net
Adrià Mercader
More information about the Pycsw-devel mailing list
