[pycsw-devel] CSW 2.0.2 - APISO 1.0 Implementation
Tom Kralidis
tomkralidis at hotmail.com
Wed Mar 30 16:44:48 EDT 2011
Thanks Angelos. FYI we will start to roll this into trunk in the next month or so. I've started a profile dev documentation page at http://sourceforge.net/apps/trac/pycsw/wiki/ProfileSupport to get high level ideas (most of which come from your sandbox).
..Tom
Date: Wed, 30 Mar 2011 04:07:08 +0300
To: pycsw-devel at lists.sourceforge.net
Subject: Re: [pycsw-devel] CSW 2.0.2 - APISO 1.0 Implementation
Right now the ISO profile is being developed as a plugin.
It can be enabled by the main configuration file and it also have
its own configuration file to hold specific information.
I am trying to insert few lines of code in the core DC model, and
the profile code will have to implement some specific functions to
plug in to the core (eg Extended Capabilities).
There is only one major chunk of code in the core model, which
involves the get_profile() function. We probably have to move this
code in the future...
Also in the sandbox, there is some initial work for INSPIRE.
Regards,
Angelos
On 03/28/2011 04:41 PM, Tom Kralidis wrote:
.ExternalClass .ecxhmmessage P
{padding:0px;}
.ExternalClass body.ecxhmmessage
{font-size:10pt;font-family:Tahoma;}
We want to extend the current model by adding the ISO specifics
via profile. We should also consider the DC model as "default".
Any profile will have to map back to the core DC model core
queryables.
Once the profile is loaded, then the CSW request processing
continues like any other request. For each profile found, the
model is extended (probably in CSW init).
..Tom
Angelos Tzotsos
Remote Sensing Laboratory
National Technical University of Athens
http://users.ntua.gr/tzotsos
Enable your software for Intel(R) Active Management Technology to meet the
growing manageability and security demands of your customers. Businesses
are taking advantage of Intel(R) vPro (TM) technology - will your software
be a part of the solution? Download the Intel(R) Manageability Checker
today! http://p.sf.net/sfu/intel-dev2devmar
pycsw-devel mailing list
https://lists.sourceforge.net/lists/listinfo/pycsw-devel
More information about the Pycsw-devel
