[pycsw-devel] migration to github
Angelos Tzotsos
gcpp.kalxas at gmail.com
Fri Jun 22 07:44:22 PDT 2012
Hi Tom,
+1 on moving to github now.
It has been a quiet period on svn and this is great opportunity.
OWSLib should be used outside of pycsw as a dependency. This is why I am
now creating packages for OWSLib on all major platforms, in order to
have this in place for 1.4.0.
Also +1 on pip, easy_install solution :)
Regards,
Angelos
On 06/22/2012 03:30 AM, Tom Kralidis wrote:
> All: there has been discussion in migrating the codebase from svn to git, which will gives us all the benefits of using git, as well as using github as the platform, with its many features.
> Currently, we have pycsw on github (http://github.com/geopython/pycsw) which is a mirror of our sf.net svn repo.
> I propose the following:
> - issue tracker: port tickets from sf.net trac to github issues. I've tested this with success at https://github.com/tomkralidis/pycsw-trac-test/issues
> - codebase: I've updated the github mirror to include all branches/tags
> - wiki: we don't have too much content, so this will not be much porting
> - website: unchanged, since we use OSGeo infrastructure
> The one issue we will need to investigate is the OWSLib dependency, which is currently an svn external (OWSLib has migrated to github, so we have to update this regardless), so we could use either a setup.py install_requires parameter or use pip.
> I will take care of the migration and update the release packaging steps. The codebase is quiet right now so it would be a good time to migrate.
> Thoughts/comments/objections?
> Thanks
> ..Tom
> pycsw-devel mailing list
> pycsw-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pycsw-devel
Angelos Tzotsos
Remote Sensing Laboratory
National Technical University of Athens
http://users.ntua.gr/tzotsos
URL: <http://lists.osgeo.org/pipermail/pycsw-devel/attachments/20120622/434fa4e6/attachment.html>
More information about the pycsw-devel
