[pycsw-devel] Running on Windows 2008 Server IIS7
Godfrey, Bruce
bgodfrey at uidaho.edu
Wed Mar 14 15:47:35 EDT 2012
I added system added environment variable for 'HTTP_HOST' and
'REQUEST_URI'. That appears to have gotten me further along. But, I
have another hurdle to clear it appears. See below.
I've got simple test python scripts working in the same web directory as
cws.py. They can be seen here:
http://dev.insideidaho.org/pycsw/test.py and
http://dev.insideidaho.org/pycsw/test2.py. So, I think (fingers
crossed) that I have the web server configured correctly but maybe I am
overlooking something.
When I use the pycsw tester to try make a GetCapabilities request I get
a 502 error. Pycsw tester is here:
http://dev.insideidaho.org/pycsw/tester/index.html
When I run pycsw on the localhost machine I get this response with more
details:
#############################BEGIN
RESPONSE#################################
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN"
"http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<title>IIS 7.0 Detailed Error - 502.2 - Bad Gateway</title>
<style type="text/css">
body{margin:0;font-size:.7em;font-family:Verdana,Arial,Helvetica,sans-se
rif;background:#CBE1EF;}
code{margin:0;color:#006600;font-size:1.1em;font-weight:bold;}
.config_source code{font-size:.8em;color:#000000;}
pre{margin:0;font-size:1.4em;word-wrap:break-word;}
ul,ol{margin:10px 0 10px 40px;}
ul.first,ol.first{margin-top:5px;}
fieldset{padding:0 15px 10px 15px;}
.summary-container fieldset{padding-bottom:5px;margin-top:4px;}
legend.no-expand-all{padding:2px 15px 4px 10px;margin:0 0 0 -12px;}
legend{color:#333333;padding:4px 15px 4px 10px;margin:4px 0 8px
-12px;_margin-top:0px;
border-top:1px solid #EDEDED;border-left:1px solid
#EDEDED;border-right:1px solid #969696;
border-bottom:1px solid
#969696;background:#E7ECF0;font-weight:bold;font-size:1em;}
a:link,a:visited{color:#007EFF;font-weight:bold;}
a:hover{text-decoration:none;}
h1{font-size:2.4em;margin:0;color:#FFF;}
h2{font-size:1.7em;margin:0;color:#CC0000;}
h3{font-size:1.4em;margin:10px 0 0 0;color:#CC0000;}
h4{font-size:1.2em;margin:10px 0 5px 0;
}#header{width:96%;margin:0 0 0 0;padding:6px 2% 6px
2%;font-family:"trebuchet MS",Verdana,sans-serif;
color:#FFF;background-color:#5C87B2;
}#content{margin:0 0 0 2%;position:relative;}
.summary-container,.content-container{background:#FFF;width:96%;margin-t
op:8px;padding:10px;position:relative;}
.config_source{background:#fff5c4;}
.content-container p{margin:0 0 10px 0;
}#details-left{width:35%;float:left;margin-right:2%;
}#details-right{width:63%;float:left;
}#server_version{width:96%;_height:1px;min-height:1px;margin:0 0 5px
0;padding:11px 2% 8px 2%;color:#FFFFFF;
background-color:#5A7FA5;border-bottom:1px solid #C1CFDD;border-top:1px
solid #4A6C8E;font-weight:normal;
font-size:1em;color:#FFF;text-align:right;
}#server_version p{margin:5px 0;}
table{margin:4px 0 4px 0;width:100%;border:none;}
td,th{vertical-align:top;padding:3px
0;text-align:left;font-weight:bold;border:none;}
th{width:30%;text-align:right;padding-right:2%;font-weight:normal;}
thead th{background-color:#ebebeb;width:25%;
}#details-right th{width:20%;}
table tr.alt td,table tr.alt th{background-color:#ebebeb;}
.highlight-code{color:#CC0000;font-weight:bold;font-style:italic;}
.clear{clear:both;}
.preferred{padding:0 5px 2px
5px;font-weight:normal;background:#006633;color:#FFF;font-size:.8em;}
</style>
</head>
<body>
<div id="header"><h1>Server Error in Application "DEFAULT WEB
SITE/PYCSW"</h1></div>
<div id="server_version"><p>Internet Information Services 7.0</p></div>
<div id="content">
<div class="content-container">
<fieldset><legend>Error Summary</legend>
<h2>HTTP Error 502.2 - Bad Gateway</h2>
<h3>The specified CGI application misbehaved by not returning a
complete set of HTTP headers. The headers it did return are
"Traceback (most recent call last):
File
"C:\criticalApplications\console\pycsw\pycsw-1.0.0\csw.py",
line 34, in <module>
from server import server
File
"C:\criticalApplications\console\pycsw\pycsw-1.0.0\server\server.py
", line 40, in <module>
import config, fes, log, profile, repository, util
File
"C:\criticalApplications\console\pycsw\pycsw-1.0.0\server\repositor
y.py", line 33, in <module>
from sqlalchemy import create_engine, desc, func
ImportError: No module named sqlalchemy
".</h3>
</fieldset>
</div>
<fieldset><legend>Detailed Error Information</legend>
<div id="details-left">
<table border="0" cellpadding="0" cellspacing="0">
<tr class="alt"><th>Module</th><td>CgiModule</td></tr>
<tr><th>Notification</th><td>ExecuteRequestHandler</td></tr>
<tr class="alt"><th>Handler</th><td>Python</td></tr>
<tr><th>Error Code</th><td>0x00000001</td></tr>
</table>
</div>
<div id="details-right">
<tr class="alt"><th>Requested
URL</th><td>http://dev.insideidaho.org:80/pycsw/csw.py</td></tr>
<tr><th>Physical
Path</th><td>C:\criticalApplications\console\pycsw\pycsw-1.0.0\csw.py</t
d></tr>
<tr class="alt"><th>Logon Method</th><td>Anonymous</td></tr>
<tr><th>Logon User</th><td>Anonymous</td></tr>
</table>
<div class="clear"></div>
</div>
</fieldset>
</div>
<fieldset><legend>Most likely causes:</legend>
<ul> <li>The CGI process was shut down or terminated unexpectedly
before it finished processing the request.</li> <li>The
CGI process has a flaw and does not return a complete set of HTTP
headers.</li> </ul>
</fieldset>
</div>
<fieldset><legend>Things you can try:</legend>
<ul> <li>Check the event logs on the system to see whether the CGI
process is shutting down unexpectedly.</li>
<li>Troubleshoot the CGI application to determine why it is not sending
a complete set of HTTP headers.</li> </ul>
</fieldset>
</div>
<fieldset><legend>Links and More Information</legend>
This error occurs when the CGI process handling the request exits
before it finishes sending the response to IIS.
<p><a
href="http://go.microsoft.com/fwlink/?LinkID=62293&IIS70Error=502,2,
0x00000001,6002">View more information »</a></p>
</fieldset>
</div>
</div>
</body>
</html>
#############################END
Note that "sqlalchemy' show up in the list when I use "help('modules')"
It seems like the crux of the issue is that IIS7 doesn't like the way
the HTTP headers being returned by the pycsw script(s). Maybe a syntax
issue? I'm not sure. I'm definitely no expert. Since I can run the
test.py scripts I'm hoping that the web server is configured properly.
If not I'm not quite sure where to look at this point. But, maybe it is
still an IIS7 configuration issue.
Ideas on how to troubleshoot this or get it working?
Thanks much!
-Bruce
From: Angelos Tzotsos [mailto:gcpp.kalxas at gmail.com]
Sent: Tuesday, March 13, 2012 6:08 PM
To: Godfrey, Bruce
Cc: pycsw-devel at lists.sourceforge.net
Subject: Re: [pycsw-devel] Running on Windows 2008 Server IIS7
Hi Bruce,
Yes, it seems that this issue is Windows specific. The "HTTP_HOST"
variable is not set in the environment variables.
Please try this from a Python console:
import os
os.environ
and send the output.
Thanks,
Angelos
On 03/14/2012 01:29 AM, Godfrey, Bruce wrote:
Hi Angelos,
Yes, thank you, I was able to get it working using the syntax
C:\\www\\pycsw
I've run into this issue now:
File "C:\criticalApplications\console\pycsw\pycsw-1.0.0\csw.py", line
40, in <module>
CSW.dispatch()
File
"C:\criticalApplications\console\pycsw\pycsw-1.0.0\server\server.py",
line 161, in dispatch
(os.environ['HTTP_HOST'], os.environ['REQUEST_URI'])
File "C:\Python27\lib\os.py", line 423, in __getitem__
return self.data[key.upper()]
KeyError: 'HTTP_HOST'
I think I'm close but I'm not sure where to look to try to track this
down. I wonder if it is an IIS7 issue?
-Bruce
Sent: Tuesday, March 13, 2012 4:22 PM
To: pycsw-devel at lists.sourceforge.net
Hello Bruce,
Did you try the windows path like c:\path\to\pycsw ?
Regards,
Angelos
On 03/13/2012 04:44 AM, Godfrey, Bruce wrote:
Hello,
I'm attempting to get pycsw running on a Windows 2008 box with IIS7. I
have all the supporting libraries installed and I have SQLite3. I'll
preface this by saying I have pretty limited experience with python.
I've changed the first line of csw.py to: #!/Python27/python -u
At this point I need edit default.cfg, correct?
What is the correct syntax for: home=/var/www/pycsw on Windows? Is it
like: c:\path\to\defaul.cfg?
Thank you for any assistance in getting this running on my Windows box.
I really appreciate it.
-Bruce
Keep Your Developer Skills Current with LearnDevNow!
The most comprehensive online learning library for Microsoft developers
is just $99.99! Visual Studio, SharePoint, SQL - plus HTML5, CSS3, MVC3,
Metro Style Apps, more. Free future releases when you subscribe now!
http://p.sf.net/sfu/learndevnow-d2d
pycsw-devel mailing list
https://lists.sourceforge.net/lists/listinfo/pycsw-devel
Angelos Tzotsos
Remote Sensing Laboratory
National Technical University of Athens
http://users.ntua.gr/tzotsos
Angelos Tzotsos
URL: http://lists.osgeo.org/pipermail/pycsw-devel/attachments/20120314/85b8b398/attachment.html
More information about the Pycsw-devel
