[pycsw-devel] Running on Windows 2008 Server IIS7
    Angelos Tzotsos
    gcpp.kalxas at gmail.com
    Tue Mar 13 21:08:03 EDT 2012
Hi Bruce,
Yes, it seems that this issue is Windows specific. The "HTTP_HOST"
variable is not set in the environment variables.
Please try this from a Python console:
import os
os.environ
and send the output.
Thanks,
Angelos
On 03/14/2012 01:29 AM, Godfrey, Bruce wrote:
> Hi Angelos,
> Yes, thank you, I was able to get it working using the syntax
> C:\\www\\pycsw
> I've run into this issue now:
> Traceback (most recent call last):
>   File "C:\criticalApplications\console\pycsw\pycsw-1.0.0\csw.py",
> line 40, in <module>
>     CSW.dispatch()
>   File
> "C:\criticalApplications\console\pycsw\pycsw-1.0.0\server\server.py",
> line 161, in dispatch
>     (os.environ['HTTP_HOST'], os.environ['REQUEST_URI'])
>   File "C:\Python27\lib\os.py", line 423, in __getitem__
>     return self.data[key.upper()]
> KeyError: 'HTTP_HOST'
> I think I'm close but I'm not sure where to look to try to track this
> down.  I wonder if it is an IIS7 issue?
> -Bruce
> *From:*Angelos Tzotsos [mailto:gcpp.kalxas at gmail.com]
> *Sent:* Tuesday, March 13, 2012 4:22 PM
> *To:* pycsw-devel at lists.sourceforge.net
> *Subject:* Re: [pycsw-devel] Running on Windows 2008 Server IIS7
> Hello Bruce,
> Did you try the windows path like c:\path\to\pycsw ?
> Regards,
> Angelos
> On 03/13/2012 04:44 AM, Godfrey, Bruce wrote:
> Hello,
> I'm attempting to get pycsw running on a Windows 2008 box with IIS7.
> I have all the supporting libraries installed and I have SQLite3.
> I'll preface this by saying I have pretty limited experience with python.
> I've changed the first line of csw.py to: #!/Python27/python -u
> At this point I need edit default.cfg, correct?
> What is the correct syntax for: home=/var/www/pycsw on Windows?  Is it
> like: c:\path\to\defaul.cfg?
> Thank you for any assistance in getting this running on my Windows
> box.  I really appreciate it.
> -Bruce
> Keep Your Developer Skills Current with LearnDevNow!
> The most comprehensive online learning library for Microsoft developers
> is just $99.99! Visual Studio, SharePoint, SQL - plus HTML5, CSS3, MVC3,
> Metro Style Apps, more. Free future releases when you subscribe now!
> http://p.sf.net/sfu/learndevnow-d2d
> pycsw-devel mailing list
> pycsw-devel at lists.sourceforge.net  <mailto:pycsw-devel at lists.sourceforge.net>
> https://lists.sourceforge.net/lists/listinfo/pycsw-devel
> Angelos Tzotsos
> Remote Sensing Laboratory
> National Technical University of Athens
> http://users.ntua.gr/tzotsos
Angelos Tzotsos
URL: http://lists.osgeo.org/pipermail/pycsw-devel/attachments/20120314/045fff70/attachment.html
More information about the Pycsw-devel
