[pycsw-devel] Problem with harvesting from another csw server
kathrin at waterinsight.nl kathrin at waterinsight.nl
Wed May 30 09:36:22 PDT 2012
Hello list,
I have just started testing pycsw for our meta data catalogue and am
quite impressed so far. Great work!
However, I have now stumbled upon a problem when using the harvesting
operation. I have enabled transactions in the default.cfg file and the
harvesting test from the test suite works (after changing ResourceType
from http://www.isotc211.org/schemas/2005/gmd/ to
http://www.isotc211.org/2005/gmd). However, this only harvests
individual metadata files. What I want to do is to harvest all records
from another CSW server. So, from what I understand, I would have to
change ResourceType to http://www.opengis.net/cat/csw/2.0.2 and give
the link to the capabilities document as Source.
So, my query is:
<Harvest xmlns="http://www.opengis.net/cat/csw/2.0.2"
xmlns:ogc="http://www.opengis.net/ogc"
xmlns:gmd="http://www.isotc211.org/2005/gmd"
xmlns:ows="http://www.opengis.net/ows"
xmlns:xsd="http://www.w3.org/2001/XMLSchema"
xmlns:dc="http://purl.org/dc/elements/1.1/"
xmlns:dct="http://purl.org/dc/terms/"
xmlns:gml="http://www.opengis.net/gml"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://www.opengis.net/cat/csw/2.0.2
http://schemas.opengis.net/csw/2.0.2/CSW-publication.xsd"
service="CSW" version="2.0.2">
<Source>
http://aiolos.survey.ntua.gr/pycsw/csw.py?service=CSW&version=2.0.2&request=GetCapabilities
</Source>
<ResourceType>http://www.opengis.net/cat/csw/2.0.2</ResourceType>
<ResourceFormat>application/xml</ResourceFormat>
</Harvest>
And the exception I get is:
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<!-- pycsw 1.2.0 -->
<ows:ExceptionReport xmlns:dc="http://purl.org/dc/elements/1.1/"
xmlns:inspire_common="http://inspire.ec.europa.eu/schemas/common/1.0"
xmlns:xs="http://www.w3.org/2001/XMLSchema"
xmlns:apiso="http://www.opengis.net/cat/csw/apiso/1.0"
xmlns:dif="http://gcmd.gsfc.nasa.gov/Aboutus/xml/dif/"
xmlns:xlink="http://www.w3.org/1999/xlink"
xmlns:gco="http://www.isotc211.org/2005/gco"
xmlns:srv="http://www.isotc211.org/2005/srv"
xmlns:fgdc="http://www.opengis.net/cat/csw/csdgm"
xmlns:inspire_ds="http://inspire.ec.europa.eu/schemas/inspire_ds/1.0"
xmlns:csw="http://www.opengis.net/cat/csw/2.0.2"
xmlns:os="http://a9.com/-/spec/opensearch/1.1/"
xmlns:soapenv="http://www.w3.org/2003/05/soap-envelope"
xmlns:sitemap="http://www.sitemaps.org/schemas/sitemap/0.9"
version="1.2.0" language="en-US"
xsi:schemaLocation="http://www.opengis.net/ows
http://schemas.opengis.net/ows/1.0.0/owsExceptionReport.xsd">
<ows:Exception locator="service" exceptionCode="InvalidRequest">
  <ows:ExceptionText>Exception: document not well-formed.
Error: EntityRef: expecting ';', line 3, column 72.</ows:ExceptionText>
</ows:Exception>
</ows:ExceptionReport>
Is there something here that I am missing? Pycsw version is 1.2.0,
python 2.6.6 running on Debian squeeze.
Any help will be appreciated!
Best regards,
Kathrin
URL: <http://lists.osgeo.org/pipermail/pycsw-devel/attachments/20120530/580ae544/attachment.html>
More information about the pycsw-devel mailing list
