[pycsw-devel] General CSW questions
Angelos Tzotsos
gcpp.kalxas at gmail.com
Fri Jul 19 16:09:20 PDT 2013
Ryan, this is a very good point.
We need to look at this. Perhaps a feature ticket?
Thanks,
Angelos
On Fri, Jul 19, 2013 at 7:43 PM, Ryan Clark <ryan.clark at azgs.az.gov> wrote:
> It seems to me that for documents like metadata, straight-up Git should be
> the version control tool of choice. Has anyone looked into trying to use a
> Git repository as a pycsw backend? CSW providing a search interface and Git
> as an alternative to CSW-T?
> Ryan
> On Jul 19, 2013, at 9:09 AM, Jeffrey Johnson <ortelius at gmail.com> wrote:
> > On Fri, Jul 19, 2013 at 4:06 AM, Tom Kralidis <tomkralidis at hotmail.com>
> wrote:
> >>> From: iedwards.pub at gmail.com
> >>> Date: Fri, 19 Jul 2013 10:03:21 +0100
> >>> To: pycsw-devel at lists.osgeo.org
> >>> Subject: [pycsw-devel] General CSW questions
> >>> Is there a forum anywhere for generic CSW questions? I'm new to CSW
> and pycsw and I have a few up front>questions that I've been unable to find
> answers to before getting stuck in.
> >> fwiw, the OGC Forum exists for generic questions, see
> http://www.ogcnetwork.net/forum/18 for CSW.
> >>> I'm trying to determine whether all transactions can/should take place
> through the CSW (CSW-T)>interfaces.
> >> CSW-T supports the following use cases:
> >> - insert a full metadata record
> >> - update metadata records
> >> - in full or a specific part of it (queryable, XPath)
> >> - supports bulk updates using OGC Filter syntax
> >> - delete metadata records
> >> - supports bulk deletes using OGC Filter syntax
> >> - harvesting disparate metadata
> >>> I'm interested in:a) accessing change log (revision history) of
> metadata records - including who made>changes, date/time of modification
> etc.
> >> This is not supported in CSW-T per se, however some metadata management
> environments probably support this (I'm thinking GeoNetwork).
> >> The GeoNode project (http://geonode.org), which is powered by pycsw,
> is experimenting with GeoGit (http://geogit.org) for data/metadata, but
> I'm not sure how mature this is yet.
> > Not sure that GeoGit is a good fit for this kind of thing, might be
> > able to be made to do this, but its primary goal is to version the
> > data. We have looked at things like django-reversion
> > https://github.com/etianen/django-reversion inside GeoNode to do
> > versioning on the metadata records and I suspect it wouldnt be that
> > difficult to implement, but we just havent done it yet.
> >>> b) high granularity of access control, e.g. anyone can edit DC fields
> in a metadata record, but only>designated people can edit the custom
> "approved" or "authorized" fields in the same record.
> >> This is out of scope for CSW-T, as authentication mechanisms are left
> to the implementation. Having said this, I haven't seen this level of
> granularity out there.
> >>> c) can database migrations be managed for evolving the structure of
> metadata records? (changes to>database schema in repeatable and consistent
> ways).
> >> Not CSW-T per se, however implementations certainly deal with this.
> GeoNode includes a metadata management environment and metadata
> migrations are made possible using South.
> >> Hope this helps.
> >> _______________________________________________
> >> pycsw-devel mailing list
> >> http://lists.osgeo.org/mailman/listinfo/pycsw-devel
Angelos Tzotsos
Remote Sensing Laboratory
National Technical University of Athens
http://users.ntua.gr/tzotsos
URL: <http://lists.osgeo.org/pipermail/pycsw-devel/attachments/20130720/12a79ba2/attachment.html>
More information about the pycsw-devel
