[pycsw-devel] Insert service metadata
Daniel Kürner
danielkuerner at googlemail.com
Tue Jun 4 07:47:10 PDT 2013
Hi Tom,
thanks for the hint. OWSLib was actually version 0.6 on our server, so
I updated via easy_install to 0.7.2.
Unfortunately, I still receive the following error on Insert. Why does
the ExceptionReport refer to the MD_DataIdentification object ? To my
knowledge, the property identificationInfo
of the MD_Metadata object is of type SV_ServiceIdentification when it
comes to service metadata.
"Transaction (insert) failed: record parsing failed:
'MD_DataIdentification' object has no attribute 'temporalextent_start'
Harvesting the service metadata directly is something we could have
considered and also might consider briefly.
Thx again for your help, much appreciated!
kind regards
daniel
2013/5/29 Tom Kralidis <tomkralidis at hotmail.com>
> Daniel: thanks for the info. Against master this works for me with no
> issue.
> What version of OWSLib are you using in this instance? Should be 0.7.2 (as
> per setup.py).
> Having said this, the metadata looks like a WMS record. Any reason you are
> not harvesting the WMS directly?
> Sent from my iPhone
> On 2013-05-29, at 9:17, "Daniel Kürner" <danielkuerner at googlemail.com>
> wrote:
> Hi,
> I am currently trying to insert ISO19139 compliant service metadata via
> the manager operation csw:Insert.
> Here is a pastebin of the dataset I am trying to insert and the resulting
> ExceptionReport:
> http://pastebin.com/7zP0tGqt
> Any ideas why the action is unsuccessful ?
> Since the hierarchyLevel is service, MD_DataIdentification is absent and
> replaced with SV_ServiceIdentification
> Thanks for any advice
> Daniel
> pycsw-devel mailing list
> pycsw-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pycsw-devel
URL: <http://lists.osgeo.org/pipermail/pycsw-devel/attachments/20130604/e283a0c3/attachment.html>
More information about the pycsw-devel
