[pycsw-devel] Insert service metadata
Tom Kralidis tomkralidis at hotmail.com
Wed Jun 12 18:09:15 PDT 2013
FYI in offline investigation with Daniel, we discovered that this was a multiple pycsw install versioning issue.  Cleaning up / sorting pycsw libraries fixed this issue.
Date: Tue, 4 Jun 2013 16:47:10 +0200
Subject: Re: [pycsw-devel] Insert service metadata
To: tomkralidis at hotmail.com; pycsw-devel at lists.osgeo.org
Hi Tom,
thanks for the hint. OWSLib was actually version 0.6 on our server, so I updated via easy_install to 0.7.2.
Unfortunately, I still receive the following error on Insert. Why does the ExceptionReport refer to the MD_DataIdentification object ? To my knowledge, the property identificationInfo
of the MD_Metadata object is of type SV_ServiceIdentification when it comes to service metadata.
"Transaction (insert) failed: record parsing failed: 'MD_DataIdentification' object has no attribute 'temporalextent_start'
Harvesting the service metadata directly is something we could have considered and also might consider briefly.
Thx again for your help, much appreciated!
kind regards
daniel
2013/5/29 Tom Kralidis <tomkralidis at hotmail.com>
Daniel: thanks for the info. Against master this works for me with no issue.
What version of OWSLib are you using in this instance? Should be 0.7.2 (as per setup.py).
Having said this, the metadata looks like a WMS record. Any reason you are not harvesting the WMS directly?
Sent from my iPhone
On 2013-05-29, at 9:17, "Daniel Kürner" <danielkuerner at googlemail.com> wrote:
I am currently trying to insert ISO19139 compliant service metadata via the manager operation csw:Insert.
Here is a pastebin of the dataset I am trying to insert and the resulting ExceptionReport:
http://pastebin.com/7zP0tGqt
Any ideas why the action is unsuccessful ?
Since the hierarchyLevel is service, MD_DataIdentification is absent and replaced with SV_ServiceIdentification
Thanks for any advice
Daniel
pycsw-devel mailing list
http://lists.osgeo.org/mailman/listinfo/pycsw-devel
URL: <http://lists.osgeo.org/pipermail/pycsw-devel/attachments/20130612/89f17996/attachment.html>
More information about the pycsw-devel mailing list
