[pycsw-devel] Preparing Postgres/Postgis DB
Tom Kralidis
tomkralidis at hotmail.com
Thu May 23 14:00:03 PDT 2013
Jeff: pycsw 1.4.1 does not include PostGIS support for native tables (only for using functions). Can you _not_ setup spatial_ref_sys and geometry_columns?
The next release of pycsw takes care of this issue.
Sent from my iPhone
On 2013-05-23, at 16:21, "Jeff McKenna" <jmckenna at gatewaygeomatics.com> wrote:
> Hello all,
> (I apologize if this is a simple question/answer)
> I have created a new PostgreSQL database (named "pycsw-demo"), and
> loaded the PostGIS extension (I'm using PostGIS 2.0.2). So, this db has
> a single existing table, named "spatial_ref_sys".
> However when I try to setup_db it I get the following error, like it is
> not happy that this spatial table already exists:
> python ./sbin/pycsw-admin.py -c setup_db -f default.cfg
> Initializing static context
> Creating database postgresql://postgres:xxxx@yyyyy:5435/pycsw-demo
> Creating table spatial_ref_sys
> Traceback (most recent call last):
> File "./sbin/pycsw-admin.py", line 239, in <module>
> admin.setup_db(DATABASE, TABLE, HOME)
> File
> "C:\Python26\Scripts\pycsw-workshop\lib\site-packages\pycsw\admin.py",
> line 62, in
> setup_db
> srs.create()
> File "build\bdist.win32\egg\sqlalchemy\schema.py", line 614, in create
> File "build\bdist.win32\egg\sqlalchemy\engine\base.py", line 1479, in
> _run_visitor
> File "build\bdist.win32\egg\sqlalchemy\engine\base.py", line 1122, in
> _run_visitor
> File "build\bdist.win32\egg\sqlalchemy\sql\visitors.py", line 111, in
> traverse_single
> File "build\bdist.win32\egg\sqlalchemy\engine\ddl.py", line 89, in
> visit_table
> File "build\bdist.win32\egg\sqlalchemy\engine\base.py", line 662, in
> execute
> File "build\bdist.win32\egg\sqlalchemy\engine\base.py", line 720, in
> _execute_ddl
> File "build\bdist.win32\egg\sqlalchemy\engine\base.py", line 874, in
> _execute_context
> File "build\bdist.win32\egg\sqlalchemy\engine\base.py", line 1024, in
> _handle_dbapi_exce
> ption
> File "build\bdist.win32\egg\sqlalchemy\util\compat.py", line 163, in
> raise_from_cause
> File "build\bdist.win32\egg\sqlalchemy\engine\base.py", line 867, in
> _execute_context
> File "build\bdist.win32\egg\sqlalchemy\engine\default.py", line 324,
> in do_execute
> sqlalchemy.exc.ProgrammingError: (ProgrammingError) relation
> "spatial_ref_sys" already exi
> sts
> '\nCREATE TABLE spatial_ref_sys (\n\tsrid SERIAL NOT NULL,
> \n\tauth_name VARCHAR(256), \n
> \tauth_srid INTEGER, \n\tsrtext VARCHAR(2048), \n\tPRIMARY KEY
> (srid)\n)\n\n' {}
> Is there something like an append setting for setup_db ?
> -jeff
> Jeff McKenna
> MapServer Consulting and Training Services
> http://www.gatewaygeomatics.com/
> pycsw-devel mailing list
> pycsw-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pycsw-devel
More information about the pycsw-devel
