[pycsw-devel] Preparing Postgres/Postgis DB
Jeff McKenna jmckenna at gatewaygeomatics.com
Thu May 23 14:04:40 PDT 2013
Thanks Tom, I will hold off on setting up spatial tables as you recommend.
-jeff
On 2013-05-23 6:00 PM, Tom Kralidis wrote:
> Jeff: pycsw 1.4.1 does not include PostGIS support for native tables (only for using functions). Can you _not_ setup spatial_ref_sys and geometry_columns?
> The next release of pycsw takes care of this issue.
> Sent from my iPhone
> On 2013-05-23, at 16:21, "Jeff McKenna" <jmckenna at gatewaygeomatics.com> wrote:
>> Hello all,
>> (I apologize if this is a simple question/answer)
>> I have created a new PostgreSQL database (named "pycsw-demo"), and
>> loaded the PostGIS extension (I'm using PostGIS 2.0.2).  So, this db has
>> a single existing table, named "spatial_ref_sys".
>> However when I try to setup_db it I get the following error, like it is
>> not happy that this spatial table already exists:
>>   python ./sbin/pycsw-admin.py -c setup_db -f default.cfg
>>    Initializing static context
>>    Creating database postgresql://postgres:xxxx@yyyyy:5435/pycsw-demo
>>    Creating table spatial_ref_sys
>>    Traceback (most recent call last):
>>      File "./sbin/pycsw-admin.py", line 239, in <module>
>>        admin.setup_db(DATABASE, TABLE, HOME)
>>      File
>> "C:\Python26\Scripts\pycsw-workshop\lib\site-packages\pycsw\admin.py",
>> line 62, in
>>    setup_db
>>        srs.create()
>>      File "build\bdist.win32\egg\sqlalchemy\schema.py", line 614, in create
>>      File "build\bdist.win32\egg\sqlalchemy\engine\base.py", line 1479, in
>> _run_visitor
>>      File "build\bdist.win32\egg\sqlalchemy\engine\base.py", line 1122, in
>> _run_visitor
>>      File "build\bdist.win32\egg\sqlalchemy\sql\visitors.py", line 111, in
>> traverse_single
>>      File "build\bdist.win32\egg\sqlalchemy\engine\ddl.py", line 89, in
>> visit_table
>>      File "build\bdist.win32\egg\sqlalchemy\engine\base.py", line 662, in
>> execute
>>      File "build\bdist.win32\egg\sqlalchemy\engine\base.py", line 720, in
>> _execute_ddl
>>      File "build\bdist.win32\egg\sqlalchemy\engine\base.py", line 874, in
>> _execute_context
>>      File "build\bdist.win32\egg\sqlalchemy\engine\base.py", line 1024, in
>> _handle_dbapi_exce
>>    ption
>>      File "build\bdist.win32\egg\sqlalchemy\util\compat.py", line 163, in
>> raise_from_cause
>>      File "build\bdist.win32\egg\sqlalchemy\engine\base.py", line 867, in
>> _execute_context
>>      File "build\bdist.win32\egg\sqlalchemy\engine\default.py", line 324,
>> in do_execute
>>    sqlalchemy.exc.ProgrammingError: (ProgrammingError) relation
>> "spatial_ref_sys" already exi
>>    sts
>>     '\nCREATE TABLE spatial_ref_sys (\n\tsrid SERIAL NOT NULL,
>> \n\tauth_name VARCHAR(256), \n
>>    \tauth_srid INTEGER, \n\tsrtext VARCHAR(2048), \n\tPRIMARY KEY
>> (srid)\n)\n\n' {}
>> Is there something like an append setting for setup_db ?
>> -jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
More information about the pycsw-devel mailing list
