[pycsw-devel] Insert service metadata
Tom Kralidis
tomkralidis at hotmail.com
Wed May 29 08:43:40 PDT 2013
Daniel: thanks for the info. Against master this works for me with no issue.
What version of OWSLib are you using in this instance? Should be 0.7.2 (as per setup.py).
Having said this, the metadata looks like a WMS record. Any reason you are not harvesting the WMS directly?
Sent from my iPhone
On 2013-05-29, at 9:17, "Daniel Kürner" <danielkuerner at googlemail.com> wrote:
> Hi,
> I am currently trying to insert ISO19139 compliant service metadata via the manager operation csw:Insert.
> Here is a pastebin of the dataset I am trying to insert and the resulting ExceptionReport:
> http://pastebin.com/7zP0tGqt
> Any ideas why the action is unsuccessful ?
> Since the hierarchyLevel is service, MD_DataIdentification is absent and replaced with SV_ServiceIdentification
> Thanks for any advice
> Daniel
> pycsw-devel mailing list
> pycsw-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pycsw-devel
URL: <http://lists.osgeo.org/pipermail/pycsw-devel/attachments/20130529/ebee6390/attachment.html>
More information about the pycsw-devel
