[pycsw-devel] Links column from ncISO
Dan Ramage
dan at inlet.geol.sc.edu
Wed Aug 27 12:22:34 PDT 2014
Now that I have my server sorted out and running properly, I notice the
links column is not getting populated.
I've run the ncISO command line against a single THREDDS endpoint for
testing. I see issue 238 is addressing the issue, however
I am wondering if that is in the master branch, I cloned the repository
from there.
There could be an issue with the ncISO metadata as well, however it looks
like the fields are there.
Dan
More information about the pycsw-devel
