[pycsw-devel] Postgres Setup, getting error during getrecords
Dan Ramage
dan at inlet.geol.sc.edu
Wed Aug 27 07:04:58 PDT 2014
I did not have postgis enabled on the database, that was my root cause.
Thanks to Tom for his help!
Dan
On 8/26/14 7:03 PM, "Tom Kralidis" <tomkralidis at gmail.com> wrote:
>On Tue, Aug 26, 2014 at 3:33 PM, Dan Ramage <dan at inlet.geol.sc.edu> wrote:
>> Hi list, just setup an instance of PyCSW with postgresql as the
>>database.
>> When I do a get records query, I am seeing the following error come
>>back:
>> Invalid query: (InternalError) ImportError: No module named pycsw
>>CONTEXT:
>> Traceback (most recent call last): PL/Python function "query_spatial",
>>line
>> 4, in <module> from pycsw import util PL/Python function "query_spatial"
>Are you running bare PostgreSQL or PostgreSQL with PostGIS? While bare
>PostgreSQL is supported it is strongly recommended to have PostGIS
>enabled.
>Base PostgreSQL support requires plpythonu support (see
>http://docs.pycsw.org/en/latest/administration.html#database-specific-note
>s).
>From the trace above it looks like it may be due to an issue with
>plpythonu.
>Can you enable your PostgreSQL with PostGIS and re-init the DB?
>> I'm running the server using: python csw.wsgi with a python virtual
>> environment. I am pretty sure there is a pathing issue going on, however
>> when I activate the python environment and "import pycsw" that works
>> properly. I'm thinking there may be something I am missing in the .wsgi
>>that
>> could be causing this.
>What does your Apache configuration look like? If you run `python
>./csw.wsgi` at the command line and run requests against
>http://localhost:8000/, do they work?
>Any chance you can provide a fuller traceback or a test URL (feel free
>to send it offline if that works better).
>> I'd appreciate any pointers.
More information about the pycsw-devel
