[pycsw-devel] CSW Harvesting using APISO possible?
Tom Kralidis
tomkralidis at gmail.com
Thu Feb 20 06:29:11 PST 2014
On Thu, Feb 20, 2014 at 7:45 AM, Michael Schulz
<mandschulz at googlemail.com> wrote:
> Hi,
> ok, I think I understood my mistake... ResourceType needs to be left as csw.
> The reason is, that the CSW I'm querying only supports gmd:MD_Metadata as
> typename and not csw:Record.
Do you mean outputschema and not typename? A valid CSW MUST support
typname csw:Record typename and outputschema
http://www.opengis.net/cat/csw/2.0.2 as baseline.
>. But I think only csw:Record is requested from
> pycsw...
Good catch. You are right, pycsw always does CSW harvesting using the
Dublin Core output, not ISO. The initial implementation of CSW
harvesting was focused on the core CSW baseline requirement of Dublin
Core, which every CSW is required to implement/support.
Having said this, sounds like a great idea to support CSW harvesting
of ISO metadata. We could probably add a configuration value which
allows the pycsw admin to specify how CSW harvesting can be done.
Can you file an enhancement ticket at
https://github.com/geopython/pycsw/issues/new ?
Thanks
..Tom
> Cheers, Michael
> 2014-02-20 13:15 GMT+01:00 Michael Schulz <mandschulz at googlemail.com>:
>> Hi,
>> I was wondering whether it should be in principle possible to harvest a
>> remote CSW returning APISO metadata records? No problem in loading them from
>> a file, but I didn't succeed in harvesting a CSW endpoint, using something
>> like this (following the example in the tester, using another local csw
>> instance):
>> <Harvest xmlns="http://www.opengis.net/cat/csw/2.0.2"
>> xmlns:ogc="http://www.opengis.net/ogc"
>> xmlns:gmd="http://www.isotc211.org/2005/gmd"
>> xmlns:ows="http://www.opengis.net/ows"
>> xmlns:xsd="http://www.w3.org/2001/XMLSchema"
>> xmlns:dc="http://purl.org/dc/elements/1.1/"
>> xmlns:dct="http://purl.org/dc/terms/" xmlns:gml="http://www.opengis.net/gml"
>> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>> xsi:schemaLocation="http://www.opengis.net/cat/csw/2.0.2
>> http://schemas.opengis.net/csw/2.0.2/CSW-publication.xsd" service="CSW"
>> version="2.0.2">
>> <Source>http://mylocal_csw_instance?request=GetCapabilities&service=CSW</Source>
>> <ResourceType>http://www.isotc211.org/schemas/2005/gmd/</ResourceType>
>> <ResourceFormat>application/xml</ResourceFormat>
>> </Harvest>
>> And if I'm not wrong, then it won't parse the metadata records, because
>> this case is not implemented in metadata.parse_record. If that's the case,
>> then it should be just about adding a new condition to check for gmd
>> resourceType and use parse_iso?
>> Cheers, Michael
More information about the pycsw-devel
