[pycsw-devel] CSW Harvesting using APISO possible?
Michael Schulz mandschulz at googlemail.com
Thu Feb 20 07:24:19 PST 2014
Hi Tom,
thanks for your answer. In the AP ISO CSW profile however it is specified,
that one of csw.Record OR gmd:MD_Metadata must be supported (csw:Record
being the default).
https://github.com/geopython/pycsw/issues/223
Do you think it would be enough to check the servers capabilities which
typename(s) is/are supported and then choose the appropriate parser in
paerse_csw?
Cheers, Michael
2014-02-20 15:29 GMT+01:00 Tom Kralidis <tomkralidis at gmail.com>:
> On Thu, Feb 20, 2014 at 7:45 AM, Michael Schulz
> <mandschulz at googlemail.com> wrote:
> > Hi,
> > ok, I think I understood my mistake... ResourceType needs to be left as
> csw.
> > The reason is, that the CSW I'm querying only supports gmd:MD_Metadata as
> > typename and not csw:Record.
> Do you mean outputschema and not typename? A valid CSW MUST support
> typname csw:Record typename and outputschema
> http://www.opengis.net/cat/csw/2.0.2 as baseline.
> >. But I think only csw:Record is requested from
> > pycsw...
> Good catch.  You are right, pycsw always does CSW harvesting using the
> Dublin Core output, not ISO.  The initial implementation of CSW
> harvesting was focused on the core CSW baseline requirement of Dublin
> Core, which every CSW is required to implement/support.
> Having said this, sounds like a great idea to support CSW harvesting
> of ISO metadata.  We could probably add a configuration value which
> allows the pycsw admin to specify how CSW harvesting can be done.
> Can you file an enhancement ticket at
> https://github.com/geopython/pycsw/issues/new ?
> Thanks
> ..Tom
> > Cheers, Michael
> > 2014-02-20 13:15 GMT+01:00 Michael Schulz <mandschulz at googlemail.com>:
> >> Hi,
> >> I was wondering whether it should be in principle possible to harvest a
> >> remote CSW returning APISO metadata records? No problem in loading them
> from
> >> a file, but I didn't succeed in harvesting a CSW endpoint, using
> something
> >> like this (following the example in the tester, using another local csw
> >> instance):
> >> <Harvest xmlns="http://www.opengis.net/cat/csw/2.0.2"
> >> xmlns:ogc="http://www.opengis.net/ogc"
> >> xmlns:gmd="http://www.isotc211.org/2005/gmd"
> >> xmlns:ows="http://www.opengis.net/ows"
> >> xmlns:xsd="http://www.w3.org/2001/XMLSchema"
> >> xmlns:dc="http://purl.org/dc/elements/1.1/"
> >> xmlns:dct="http://purl.org/dc/terms/" xmlns:gml="
> http://www.opengis.net/gml"
> >> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> >> xsi:schemaLocation="http://www.opengis.net/cat/csw/2.0.2
> >> http://schemas.opengis.net/csw/2.0.2/CSW-publication.xsd" service="CSW"
> >> version="2.0.2">
> >> <Source>http://mylocal_csw_instance?request=GetCapabilities&service=CSW
> </Source>
> >> <ResourceType>http://www.isotc211.org/schemas/2005/gmd/</ResourceType>
> >> <ResourceFormat>application/xml</ResourceFormat>
> >> </Harvest>
> >> And if I'm not wrong, then it won't parse the metadata records, because
> >> this case is not implemented in metadata.parse_record. If that's the
> case,
> >> then it should be just about adding a new condition to check for gmd
> >> resourceType and use parse_iso?
> >> Cheers, Michael
Michael Schulz
Bahnhofstr. 62
D-63477 Maintal
URL: <http://lists.osgeo.org/pipermail/pycsw-devel/attachments/20140220/19260c58/attachment-0001.html>
More information about the pycsw-devel mailing list
