[pycsw-devel] CSW Harvesting using APISO possible?
Tom Kralidis
tomkralidis at gmail.com
Thu Feb 20 11:02:25 PST 2014
Sent from my iPhone
> On Feb 20, 2014, at 10:24, Michael Schulz <mandschulz at googlemail.com> wrote:
> Hi Tom,
> thanks for your answer. In the AP ISO CSW profile however it is specified, that one of csw.Record OR gmd:MD_Metadata must be supported (csw:Record being the default).
> https://github.com/geopython/pycsw/issues/223
> Do you think it would be enough to check the servers capabilities which typename(s) is/are supported and then choose the appropriate parser in paerse_csw?
See
https://github.com/geopython/pycsw/issues/105 for more info. I you want to harvest ISO metadata it is pertinent to specify the outputschema for ISO.
For pycsw maybe we can add a setting (manager.csw_harvest_iso:true) which makes the harvest ask for ISO metadata instead of the default Dublin Core. Would this work for you?
> Cheers, Michael
> 2014-02-20 15:29 GMT+01:00 Tom Kralidis <tomkralidis at gmail.com>:
>> On Thu, Feb 20, 2014 at 7:45 AM, Michael Schulz
>> > Hi,
>> > ok, I think I understood my mistake... ResourceType needs to be left as csw.
>> > The reason is, that the CSW I'm querying only supports gmd:MD_Metadata as
>> > typename and not csw:Record.
>> Do you mean outputschema and not typename? A valid CSW MUST support
>> typname csw:Record typename and outputschema
>> http://www.opengis.net/cat/csw/2.0.2 as baseline.
>> >. But I think only csw:Record is requested from
>> > pycsw...
>> Good catch. You are right, pycsw always does CSW harvesting using the
>> Dublin Core output, not ISO. The initial implementation of CSW
>> harvesting was focused on the core CSW baseline requirement of Dublin
>> Core, which every CSW is required to implement/support.
>> Having said this, sounds like a great idea to support CSW harvesting
>> of ISO metadata. We could probably add a configuration value which
>> allows the pycsw admin to specify how CSW harvesting can be done.
>> Can you file an enhancement ticket at
>> https://github.com/geopython/pycsw/issues/new ?
>> Thanks
>> ..Tom
>> > Cheers, Michael
>> > 2014-02-20 13:15 GMT+01:00 Michael Schulz <mandschulz at googlemail.com>:
>> >> Hi,
>> >> I was wondering whether it should be in principle possible to harvest a
>> >> remote CSW returning APISO metadata records? No problem in loading them from
>> >> a file, but I didn't succeed in harvesting a CSW endpoint, using something
>> >> like this (following the example in the tester, using another local csw
>> >> instance):
>> >> <Harvest xmlns="http://www.opengis.net/cat/csw/2.0.2"
>> >> xmlns:ogc="http://www.opengis.net/ogc"
>> >> xmlns:gmd="http://www.isotc211.org/2005/gmd"
>> >> xmlns:ows="http://www.opengis.net/ows"
>> >> xmlns:xsd="http://www.w3.org/2001/XMLSchema"
>> >> xmlns:dc="http://purl.org/dc/elements/1.1/"
>> >> xmlns:dct="http://purl.org/dc/terms/" xmlns:gml="http://www.opengis.net/gml"
>> >> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>> >> xsi:schemaLocation="http://www.opengis.net/cat/csw/2.0.2
>> >> http://schemas.opengis.net/csw/2.0.2/CSW-publication.xsd" service="CSW"
>> >> version="2.0.2">
>> >> <Source>http://mylocal_csw_instance?request=GetCapabilities&service=CSW</Source>
>> >> <ResourceType>http://www.isotc211.org/schemas/2005/gmd/</ResourceType>
>> >> <ResourceFormat>application/xml</ResourceFormat>
>> >> </Harvest>
>> >> And if I'm not wrong, then it won't parse the metadata records, because
>> >> this case is not implemented in metadata.parse_record. If that's the case,
>> >> then it should be just about adding a new condition to check for gmd
>> >> resourceType and use parse_iso?
>> >> Cheers, Michael
> Michael Schulz
> Bahnhofstr. 62
> D-63477 Maintal
> pycsw-devel mailing list
> pycsw-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pycsw-devel
URL: <http://lists.osgeo.org/pipermail/pycsw-devel/attachments/20140220/1d8cddbc/attachment.html>
More information about the pycsw-devel
