[pycsw-devel] SOS Harvesting Error
dan at inlet.geol.sc.edu
Mon Oct 27 08:02:18 PDT 2014
The exception traceback on the local server:
Exception happened during processing of request from ('127.0.0.1', 45798)
File "/usr/local/src/python/lib/python2.7/SocketServer.py", line 295, in
_handle_request_noblock
self.process_request(request, client_address)
File "/usr/local/src/python/lib/python2.7/SocketServer.py", line 321, in
process_request
self.finish_request(request, client_address)
File "/usr/local/src/python/lib/python2.7/SocketServer.py", line 334, in
finish_request
self.RequestHandlerClass(request, client_address, self)
File "/usr/local/src/python/lib/python2.7/SocketServer.py", line 653, in
__init__
self.finish()
File "/usr/local/src/python/lib/python2.7/SocketServer.py", line 712, in
finish
self.wfile.close()
File "/usr/local/src/python/lib/python2.7/socket.py", line 279, in close
self.flush()
File "/usr/local/src/python/lib/python2.7/socket.py", line 303, in flush
self._sock.sendall(view[write_offset:write_offset+buffer_size])
error: [Errno 32] Broken pipe
> I am attempting to populate a test pycsw server with the offerings from
> NDBC's SOS server. I am getting an exception of:
> <ows:Exception exceptionCode="NoApplicableCode" locator="source">
> <ows:ExceptionText>Harvest (insert) failed: ERROR: index row size 3956
> exceeds maximum 2712 for index "ix_records_operateson"
> HINT: Values larger than 1/3 of a buffer page cannot be indexed.
> Consider a function index of an MD5 hash of the value, or use full text
> indexing.
> .</ows:ExceptionText>
> </ows:Exception>
> </ows:ExceptionReport>
> I am not sure what this is telling me. The xml file I am using to direct
> the pycsw-admin is:
> <?xml version="1.0" encoding="UTF-8"?>
> <Harvest xmlns="http://www.opengis.net/cat/csw/2.0.2"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xsi:schemaLocation="http://www.opengis.net/cat/csw/2.0.2
> http://schemas.opengis.net/csw/2.0.2/CSW-publication.xsd" service="CSW"
> version="2.0.2">
> <Source>http://sdf.ndbc.noaa.gov/sos/server.php</Source>
> <ResourceType>http://www.opengis.net/sos/1.0</ResourceType>
> </Harvest>
> Any pointers would be great.
> Dan
> pycsw-devel mailing list
> pycsw-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pycsw-devel
More information about the pycsw-devel
