[pycsw-devel] SOS Harvesting Error
dan at inlet.geol.sc.edu dan at inlet.geol.sc.edu
Mon Oct 27 09:48:50 PDT 2014
More info: The database backend when this is happening is PostGRES 9.2.
When I switch over to SQLITE, the processing appears to work.
I'm assuming SQLITE does not have the index limitation.
Dan
> The exception traceback on the local server:
> Exception happened during processing of request from ('127.0.0.1', 45798)
> Traceback (most recent call last):
>   File "/usr/local/src/python/lib/python2.7/SocketServer.py", line 295, in
> _handle_request_noblock
>     self.process_request(request, client_address)
>   File "/usr/local/src/python/lib/python2.7/SocketServer.py", line 321, in
> process_request
>     self.finish_request(request, client_address)
>   File "/usr/local/src/python/lib/python2.7/SocketServer.py", line 334, in
> finish_request
>     self.RequestHandlerClass(request, client_address, self)
>   File "/usr/local/src/python/lib/python2.7/SocketServer.py", line 653, in
> __init__
>     self.finish()
>   File "/usr/local/src/python/lib/python2.7/SocketServer.py", line 712, in
> finish
>     self.wfile.close()
>   File "/usr/local/src/python/lib/python2.7/socket.py", line 279, in close
>     self.flush()
>   File "/usr/local/src/python/lib/python2.7/socket.py", line 303, in flush
>     self._sock.sendall(view[write_offset:write_offset+buffer_size])
> error: [Errno 32] Broken pipe
>> I am attempting to populate a test pycsw server with the offerings from
>> NDBC's SOS server. I am getting an exception of:
>> <ows:Exception exceptionCode="NoApplicableCode" locator="source">
>>     <ows:ExceptionText>Harvest (insert) failed: ERROR: index row size
>> 3956
>> exceeds maximum 2712 for index "ix_records_operateson"
>> HINT:  Values larger than 1/3 of a buffer page cannot be indexed.
>> Consider a function index of an MD5 hash of the value, or use full text
>> indexing.
>> .</ows:ExceptionText>
>>   </ows:Exception>
>> </ows:ExceptionReport>
>> I am not sure what this is telling me. The xml file I am using to direct
>> the pycsw-admin is:
>> <?xml version="1.0" encoding="UTF-8"?>
>> <Harvest xmlns="http://www.opengis.net/cat/csw/2.0.2"
>> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>> xsi:schemaLocation="http://www.opengis.net/cat/csw/2.0.2
>> http://schemas.opengis.net/csw/2.0.2/CSW-publication.xsd" service="CSW"
>> version="2.0.2">
>>   <Source>http://sdf.ndbc.noaa.gov/sos/server.php</Source>
>>   <ResourceType>http://www.opengis.net/sos/1.0</ResourceType>
>> </Harvest>
>> Any pointers would be great.
>> Dan
>> pycsw-devel mailing list
>> pycsw-devel at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/pycsw-devel
More information about the pycsw-devel mailing list
