[pycsw-devel] SOS Harvesting Error
    dan at inlet.geol.sc.edu
    Tue Oct 28 12:19:36 PDT 2014
SOme additional logging on line 1792 of server.py
turned up a traceback of:
  File "/home/madrona/src/pycsw/pycsw/server.py", line 1792, in harvest
    pagesize=self.csw_harvest_pagesize)
  File "/home/madrona/src/pycsw/pycsw/metadata.py", line 91, in parse_record
    return _parse_sos(context, repos, record, identifier, '1.0.0')
  File "/home/madrona/src/pycsw/pycsw/metadata.py", line 700, in _parse_sos
    _set(context, recobj, 'pycsw:XML', etree.tostring(md._capabilities))
  File "lxml.etree.pyx", line 3157, in lxml.etree.tostring
(src/lxml/lxml.etree.c:69517)
  File "serializer.pxi", line 143, in lxml.etree._tostring
(src/lxml/lxml.etree.c:114600)
MemoryError
Doing a down and dirty "top" I could see that the server was most likely
running out of memory. The NDBC station where it finally died was
station-42915, I am harvesting against the NDBC SOS still.
Dan
> I've apparently taken a step further back, I can't make the parsing happen
> at all now.
> On the "client end" when I run the command python bin/pycsw-admin.py -c
> post_xml -u http://129.252.139.196:8080 -x Harvest-sos100.xml
> I get the error:
> Executing HTTP POST request Harvest-sos100.xml on server
>   File "bin/pycsw-admin.py", line 246, in <module>
>     print admin.post_xml(CSW_URL, XML, TIMEOUT)
>   File
> "/usr/local/virtualenv/venv-2.7.8/lib/python2.7/site-packages/pycsw/admin.py",
> line 495, in post_xml
>     raise RuntimeError(err)
> RuntimeError: timed out
> On the local server I see:
>   File "/usr/local/src/python/lib/python2.7/wsgiref/handlers.py", line 86,
> in run
>     self.finish_response()
> 128, in finish_response
>     self.write(data)
> 212, in write
>     self.send_headers()
> 270, in send_headers
>     self.send_preamble()
> 194, in send_preamble
>     'Date: %s\r\n' % format_date_time(time.time())
>   File "/usr/local/src/python/lib/python2.7/socket.py", line 324, in write
>     self.flush()
>   File "/usr/local/src/python/lib/python2.7/socket.py", line 303, in flush
>     self._sock.sendall(view[write_offset:write_offset+buffer_size])
> error: [Errno 32] Broken pipe
> 129.252.139.68 - - [28/Oct/2014 08:38:15] "POST / HTTP/1.1" 500 59
> Exception happened during processing of request from ('129.252.139.68',
> 51289)
>   File "/usr/local/src/python/lib/python2.7/SocketServer.py", line 295, in
> _handle_request_noblock
>     self.process_request(request, client_address)
>   File "/usr/local/src/python/lib/python2.7/SocketServer.py", line 321, in
> process_request
>     self.finish_request(request, client_address)
>   File "/usr/local/src/python/lib/python2.7/SocketServer.py", line 334, in
> finish_request
>     self.RequestHandlerClass(request, client_address, self)
>   File "/usr/local/src/python/lib/python2.7/SocketServer.py", line 653, in
> __init__
>     self.finish()
>   File "/usr/local/src/python/lib/python2.7/SocketServer.py", line 712, in
> finish
>     self.wfile.close()
>   File "/usr/local/src/python/lib/python2.7/socket.py", line 279, in close
>     self.flush()
> and finally in the log:
> file=/home/madrona/src/pycsw/pycsw/server.py line=2331 module=server
> function=_write_response Response:
> <ows:ExceptionReport xmlns:dc="http://purl.org/dc/elements/1.1/"
> xmlns:inspire_common="http://inspire.ec.europa.eu/schemas/common/1.0"
> xmlns:atom="http://www.w3.org/2005/Atom"
> xmlns:xs="http://www.w3.org/2001/XMLSchema"
> xmlns:dct="http://purl.org/dc/terms/"
> xmlns:ows="http://www.opengis.net/ows"
> xmlns:apiso="http://www.opengis.net/cat/csw/apiso/1.0"
> xmlns:gml="http://www.opengis.net/gml"
> xmlns:dif="http://gcmd.gsfc.nasa.gov/Aboutus/xml/dif/"
> xmlns:xlink="http://www.w3.org/1999/xlink"
> xmlns:gco="http://www.isotc211.org/2005/gco"
> xmlns:gmd="http://www.isotc211.org/2005/gmd"
> xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#"
> xmlns:srv="http://www.isotc211.org/2005/srv"
> xmlns:ogc="http://www.opengis.net/ogc"
> xmlns:fgdc="http://www.opengis.net/cat/csw/csdgm"
> xmlns:inspire_ds="http://inspire.ec.europa.eu/schemas/inspire_ds/1.0"
> xmlns:csw="http://www.opengis.net/cat/csw/2.0.2"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xmlns:os="http://a9.com/-/spec/opensearch/1.1/"
> xmlns:soapenv="http://www.w3.org/2003/05/soap-envelope"
> xmlns:sitemap="http://www.sitemaps.org/schemas/sitemap/0.9"
> language="en-US" version="1.2.0"
> xsi:schemaLocation="http://www.opengis.net/ows
> http://schemas.opengis.net/ows/1.0.0/owsExceptionReport.xsd">
>   <ows:Exception exceptionCode="NoApplicableCode" locator="source">
>     <ows:ExceptionText>Harvest failed: record parsing failed:
> </ows:ExceptionText>
>   </ows:Exception>
> </ows:ExceptionReport>
> pycsw-devel mailing list
> pycsw-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pycsw-devel
More information about the pycsw-devel
