[pycsw-devel] SOS Harvesting Error
dan at inlet.geol.sc.edu
Tue Oct 28 12:36:04 PDT 2014
The virtual server I was running only had 1Gb of memory and it was running
out. I bumped it up to 4Gb and the processing is now working much better.
Since the sos parsing is grabbing all the records, this could continue to
be an issue. I don't know the entire data flow, but I was thinking a less
memory intensive processing would be to run through the offerings wholly
processing one station, then the next so the memory footprint would not
continue to grow depending on the station count.
Dan
> SOme additional logging on line 1792 of server.py
> turned up a traceback of:
> Traceback (most recent call last):
> File "/home/madrona/src/pycsw/pycsw/server.py", line 1792, in harvest
> pagesize=self.csw_harvest_pagesize)
> File "/home/madrona/src/pycsw/pycsw/metadata.py", line 91, in
> parse_record
> return _parse_sos(context, repos, record, identifier, '1.0.0')
> File "/home/madrona/src/pycsw/pycsw/metadata.py", line 700, in
> _parse_sos
> _set(context, recobj, 'pycsw:XML', etree.tostring(md._capabilities))
> File "lxml.etree.pyx", line 3157, in lxml.etree.tostring
> (src/lxml/lxml.etree.c:69517)
> File "serializer.pxi", line 143, in lxml.etree._tostring
> (src/lxml/lxml.etree.c:114600)
> MemoryError
> Doing a down and dirty "top" I could see that the server was most likely
> running out of memory. The NDBC station where it finally died was
> station-42915, I am harvesting against the NDBC SOS still.
> Dan
>> I've apparently taken a step further back, I can't make the parsing
>> happen
>> at all now.
>> On the "client end" when I run the command python bin/pycsw-admin.py -c
>> post_xml -u http://129.252.139.196:8080 -x Harvest-sos100.xml
>> I get the error:
>> Executing HTTP POST request Harvest-sos100.xml on server
>> File "bin/pycsw-admin.py", line 246, in <module>
>> print admin.post_xml(CSW_URL, XML, TIMEOUT)
>> File
>> "/usr/local/virtualenv/venv-2.7.8/lib/python2.7/site-packages/pycsw/admin.py",
>> line 495, in post_xml
>> raise RuntimeError(err)
>> RuntimeError: timed out
>> On the local server I see:
>> File "/usr/local/src/python/lib/python2.7/wsgiref/handlers.py", line
>> 86,
>> in run
>> self.finish_response()
>> 128, in finish_response
>> self.write(data)
>> 212, in write
>> self.send_headers()
>> 270, in send_headers
>> self.send_preamble()
>> 194, in send_preamble
>> 'Date: %s\r\n' % format_date_time(time.time())
>> File "/usr/local/src/python/lib/python2.7/socket.py", line 324, in
>> write
>> self.flush()
>> File "/usr/local/src/python/lib/python2.7/socket.py", line 303, in
>> flush
>> self._sock.sendall(view[write_offset:write_offset+buffer_size])
>> error: [Errno 32] Broken pipe
>> 129.252.139.68 - - [28/Oct/2014 08:38:15] "POST / HTTP/1.1" 500 59
>> Exception happened during processing of request from ('129.252.139.68',
>> 51289)
>> File "/usr/local/src/python/lib/python2.7/SocketServer.py", line 295,
>> in
>> _handle_request_noblock
>> self.process_request(request, client_address)
>> File "/usr/local/src/python/lib/python2.7/SocketServer.py", line 321,
>> in
>> process_request
>> self.finish_request(request, client_address)
>> File "/usr/local/src/python/lib/python2.7/SocketServer.py", line 334,
>> in
>> finish_request
>> self.RequestHandlerClass(request, client_address, self)
>> File "/usr/local/src/python/lib/python2.7/SocketServer.py", line 653,
>> in
>> __init__
>> self.finish()
>> File "/usr/local/src/python/lib/python2.7/SocketServer.py", line 712,
>> in
>> finish
>> self.wfile.close()
>> File "/usr/local/src/python/lib/python2.7/socket.py", line 279, in
>> close
>> self.flush()
>> flush
>> and finally in the log:
>> file=/home/madrona/src/pycsw/pycsw/server.py line=2331 module=server
>> function=_write_response Response:
>> <ows:ExceptionReport xmlns:dc="http://purl.org/dc/elements/1.1/"
>> xmlns:inspire_common="http://inspire.ec.europa.eu/schemas/common/1.0"
>> xmlns:atom="http://www.w3.org/2005/Atom"
>> xmlns:xs="http://www.w3.org/2001/XMLSchema"
>> xmlns:dct="http://purl.org/dc/terms/"
>> xmlns:ows="http://www.opengis.net/ows"
>> xmlns:apiso="http://www.opengis.net/cat/csw/apiso/1.0"
>> xmlns:gml="http://www.opengis.net/gml"
>> xmlns:dif="http://gcmd.gsfc.nasa.gov/Aboutus/xml/dif/"
>> xmlns:xlink="http://www.w3.org/1999/xlink"
>> xmlns:gco="http://www.isotc211.org/2005/gco"
>> xmlns:gmd="http://www.isotc211.org/2005/gmd"
>> xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#"
>> xmlns:srv="http://www.isotc211.org/2005/srv"
>> xmlns:ogc="http://www.opengis.net/ogc"
>> xmlns:fgdc="http://www.opengis.net/cat/csw/csdgm"
>> xmlns:inspire_ds="http://inspire.ec.europa.eu/schemas/inspire_ds/1.0"
>> xmlns:csw="http://www.opengis.net/cat/csw/2.0.2"
>> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>> xmlns:os="http://a9.com/-/spec/opensearch/1.1/"
>> xmlns:soapenv="http://www.w3.org/2003/05/soap-envelope"
>> xmlns:sitemap="http://www.sitemaps.org/schemas/sitemap/0.9"
>> language="en-US" version="1.2.0"
>> xsi:schemaLocation="http://www.opengis.net/ows
>> http://schemas.opengis.net/ows/1.0.0/owsExceptionReport.xsd">
>> <ows:Exception exceptionCode="NoApplicableCode" locator="source">
>> <ows:ExceptionText>Harvest failed: record parsing failed:
>> </ows:ExceptionText>
>> </ows:Exception>
>> </ows:ExceptionReport>
>> pycsw-devel mailing list
>> pycsw-devel at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/pycsw-devel
More information about the pycsw-devel
