[pycsw-devel] Harvesting from WAF/Which XML tags are used for certain fields
dan at inlet.geol.sc.edu
Wed Oct 29 09:32:27 PDT 2014
In a hopefully attempt to get better metadata, I am trying to determine
which fields in the XML metadata files are used to populate entries such
as:
creator, organization, etc. I'm looking in the metadata.py file and see
where the _set occurs, but I am not sure where the mapping from the XML to
the field occurs.
Dan
More information about the pycsw-devel
