[pycsw-devel] Harvesting from WAF/Which XML tags are used for certain fields
dan at inlet.geol.sc.edu dan at inlet.geol.sc.edu
Wed Oct 29 09:49:22 PDT 2014
Looks like config.py is where I should be looking.
> In a hopefully attempt to get better metadata, I am trying to determine
> which fields in the XML metadata files are used to populate entries such
> as:
> creator, organization, etc. I'm looking in the metadata.py file and see
> where the _set occurs, but I am not sure where the mapping from the XML to
> the field occurs.
> Dan
> pycsw-devel mailing list
> pycsw-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pycsw-devel
More information about the pycsw-devel mailing list
