[pycsw-devel] Links Question
John Maurer jmaurer at hawaii.edu
Mon Sep 22 12:08:57 PDT 2014
As the description indicates, this is just a viewer that ncISO includes as
a default option. It is not a service endpoint like OPeNDAP, WMS, NCSS,
etc. I think leaving the gmd:protocol as "None" is accurate in this case.
It is not "http", for instance, because this viewer is a Java app. In my
personal version of ncISO, I commented this section out because I did not
want the toolkit advertised in our metadata but that is just our preference.
Cheers,
John Maurer, PacIOOS
On Mon, Sep 22, 2014 at 8:56 AM, Dan Ramage <dan at inlet.geol.sc.edu> wrote:
> I've gotten most of my services issues sorted out via ncISO and using an
> xsl file that handles the transforms correctly from Thredds endpoints.
> However I still have an entry of "None" with a link that only appears in
> the following metadata section:
>                <gmd:distributorTransferOptions>
>                   <gmd:MD_DigitalTransferOptions>
>                      <gmd:onLine>
>                         <gmd:CI_OnlineResource>
>                            <gmd:linkage>
>                               <gmd:URL>
> http://www.ncdc.noaa.gov/oa/wct/wct-jnlp-beta.php?singlefile=http://omgsrv1.meas.ncsu.edu:8080/thredds/dodsC/fmrc/sabgom/SABGOM_Forecast_Model_Run_Collection_best.ncd
> </gmd:URL>
>                            </gmd:linkage>
>                            <gmd:name>
>                               <gco:CharacterString>Viewer
> Information</gco:CharacterString>
>                            </gmd:name>
>                            <gmd:description>
>                               <gco:CharacterString>This URL provides an
> NCDC climate and weather toolkit view of an OPeNDAP
> resource.</gco:CharacterString>
>                            </gmd:description>
>                            <gmd:function>
>                               <gmd:CI_OnLineFunctionCode codeList="
> http://www.ngdc.noaa.gov/metadata/published/xsd/schema/resources/Codelist/gmxCodelists.xml#CI_PresentationFormCode
>  codeListValue="mapDigital">mapDigital</gmd:CI_OnLineFunctionCode>
>                            </gmd:function>
>                         </gmd:CI_OnlineResource>
>                      </gmd:onLine>
>                   </gmd:MD_DigitalTransferOptions>
>                </gmd:distributorTransferOptions>
> Should this be picked up at all? There is a similar section above it as
> well that is a gmd:name http. I am not sure if this one is getting handled
> since I do have an http entry in the links or if that was from a
> gmd:protocol section.
> Dan
> pycsw-devel mailing list
> pycsw-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pycsw-devel
URL: <http://lists.osgeo.org/pipermail/pycsw-devel/attachments/20140922/4383278b/attachment.html>
More information about the pycsw-devel mailing list
