[pycsw-devel] Links Question
Dan Ramage dan at inlet.geol.sc.edu
Mon Sep 22 12:12:26 PDT 2014
What's the reasoning for not using the Viewer Information string?
Dan
On 9/22/14 3:06 PM, "Tom Kralidis" <tomkralidis at gmail.com> wrote:
>This should be fixed in the upsteam ncISO tools at this point:
>https://github.com/ethanrd/threddsIso/issues/2
>https://github.com/Unidata/threddsIso/pull/1
>This should alleviate this issue for ncISO based outputs.
>..Tom
>On Mon, 22 Sep 2014, Dan Ramage wrote:
>> Date: Mon, 22 Sep 2014 14:56:48 -0400
>> From: Dan Ramage <dan at inlet.geol.sc.edu>
>> To: "pycsw-devel at lists.osgeo.org" <pycsw-devel at lists.osgeo.org>
>> Subject: [pycsw-devel] Links Question
>> I've gotten most of my services issues sorted out via ncISO and using
>>an xsl
>> file that handles the transforms correctly from Thredds endpoints.
>> However I still have an entry of "None" with a link that only appears
>>in the
>> following metadata section:
>>               <gmd:distributorTransferOptions>
>>                  <gmd:MD_DigitalTransferOptions>
>>                     <gmd:onLine>
>>                        <gmd:CI_OnlineResource>
>>                           <gmd:linkage>
>><gmd:URL>http://www.ncdc.noaa.gov/oa/wct/wct-jnlp-beta.php?singlefile=htt
>>p:/
>>/omgsrv1.meas.ncsu.edu:8080/thredds/dodsC/fmrc/sabgom/SABGOM_Forecast_Mod
>>el_
>> Run_Collection_best.ncd</gmd:URL>
>>                           </gmd:linkage>
>>                           <gmd:name>
>>                              <gco:CharacterString>Viewer
>> Information</gco:CharacterString>
>>                           </gmd:name>
>>                           <gmd:description>
>>                              <gco:CharacterString>This URL provides an
>>NCDC
>> climate and weather toolkit view of an OPeNDAP
>> resource.</gco:CharacterString>
>>                           </gmd:description>
>>                           <gmd:function>
>>                              <gmd:CI_OnLineFunctionCode
>>codeList="http://www.ngdc.noaa.gov/metadata/published/xsd/schema/resource
>>s/C
>> odelist/gmxCodelists.xml#CI_PresentationFormCode"
>> codeListValue="mapDigital">mapDigital</gmd:CI_OnLineFunctionCode>
>>                           </gmd:function>
>>                        </gmd:CI_OnlineResource>
>>                     </gmd:onLine>
>>                  </gmd:MD_DigitalTransferOptions>
>>               </gmd:distributorTransferOptions>
>> Should this be picked up at all? There is a similar section above it as
>>well
>> that is a gmd:name http. I am not sure if this one is getting handled
>>since
>> I do have an http entry in the links or if that was from a gmd:protocol
>> section.
>> Dan
More information about the pycsw-devel mailing list
