[pycsw-devel] Links Question
Tom Kralidis tomkralidis at gmail.com
Mon Sep 22 12:15:34 PDT 2014
gmd:protocol is the actual element which triggers clients into binding against
a given resource, which is usually based on a codelist item for consistency.
gmd:name serves as more of a text label of a given link as opposed to
something a machine can action against.
Using gmd:protocol will yield huge value in many downstream tools like
pycsw.  And given tools are looking for gmd:protocol, this prevents
them from guessing what the link is.
..Tom
On Mon, 22 Sep 2014, Dan Ramage wrote:
> Date: Mon, 22 Sep 2014 15:12:26 -0400
> From: Dan Ramage <dan at inlet.geol.sc.edu>
> To: Tom Kralidis <tomkralidis at gmail.com>
> Cc: "pycsw-devel at lists.osgeo.org" <pycsw-devel at lists.osgeo.org>
> Subject: Re: [pycsw-devel] Links Question
> What's the reasoning for not using the Viewer Information string?
> Dan
> On 9/22/14 3:06 PM, "Tom Kralidis" <tomkralidis at gmail.com> wrote:
>> This should be fixed in the upsteam ncISO tools at this point:
>> https://github.com/ethanrd/threddsIso/issues/2
>> https://github.com/Unidata/threddsIso/pull/1
>> This should alleviate this issue for ncISO based outputs.
>> ..Tom
>>> Date: Mon, 22 Sep 2014 14:56:48 -0400
>>> To: "pycsw-devel at lists.osgeo.org" <pycsw-devel at lists.osgeo.org>
>>> Subject: [pycsw-devel] Links Question
>>> I've gotten most of my services issues sorted out via ncISO and using
>>> an xsl
>>> file that handles the transforms correctly from Thredds endpoints.
>>> However I still have an entry of "None" with a link that only appears
>>> in the
>>> following metadata section:
>>>               <gmd:distributorTransferOptions>
>>>                  <gmd:MD_DigitalTransferOptions>
>>>                     <gmd:onLine>
>>>                        <gmd:CI_OnlineResource>
>>>                           <gmd:linkage>
>>> <gmd:URL>http://www.ncdc.noaa.gov/oa/wct/wct-jnlp-beta.php?singlefile=htt
>>> p:/
>>> /omgsrv1.meas.ncsu.edu:8080/thredds/dodsC/fmrc/sabgom/SABGOM_Forecast_Mod
>>> el_
>>> Run_Collection_best.ncd</gmd:URL>
>>>                           </gmd:linkage>
>>>                           <gmd:name>
>>>                              <gco:CharacterString>Viewer
>>> Information</gco:CharacterString>
>>>                           </gmd:name>
>>>                           <gmd:description>
>>>                              <gco:CharacterString>This URL provides an
>>> NCDC
>>> climate and weather toolkit view of an OPeNDAP
>>> resource.</gco:CharacterString>
>>>                           </gmd:description>
>>>                           <gmd:function>
>>>                              <gmd:CI_OnLineFunctionCode
>>> codeList="http://www.ngdc.noaa.gov/metadata/published/xsd/schema/resource
>>> s/C
>>> odelist/gmxCodelists.xml#CI_PresentationFormCode"
>>> codeListValue="mapDigital">mapDigital</gmd:CI_OnLineFunctionCode>
>>>                           </gmd:function>
>>>                        </gmd:CI_OnlineResource>
>>>                     </gmd:onLine>
>>>                  </gmd:MD_DigitalTransferOptions>
>>>               </gmd:distributorTransferOptions>
>>> Should this be picked up at all? There is a similar section above it as
>>> well
>>> that is a gmd:name http. I am not sure if this one is getting handled
>>> since
>>> I do have an http entry in the links or if that was from a gmd:protocol
>>> section.
>>> Dan
More information about the pycsw-devel mailing list
