[pycsw-devel] Links Question
Dan Ramage
dan at inlet.geol.sc.edu
Mon Sep 22 12:21:39 PDT 2014
I think I am confused, the URL that is used for this None entry is only
found in the section I posted below. I didn't see any <gmd:protocol>
entries that had that URL.
The ISO record in question is here:
http://neptune.baruch.sc.edu/xenia/waf/ncsu_meas/thredds_dodsC_fmrc_sabgom_
SABGOM_Forecast_Model_Run_Collection_best.ncd_META.xml
On 9/22/14 3:15 PM, "Tom Kralidis" <tomkralidis at gmail.com> wrote:
>gmd:protocol is the actual element which triggers clients into binding
>against
>a given resource, which is usually based on a codelist item for
>consistency.
>gmd:name serves as more of a text label of a given link as opposed to
>something a machine can action against.
>Using gmd:protocol will yield huge value in many downstream tools like
>pycsw. And given tools are looking for gmd:protocol, this prevents
>them from guessing what the link is.
>..Tom
>On Mon, 22 Sep 2014, Dan Ramage wrote:
>> Date: Mon, 22 Sep 2014 15:12:26 -0400
>> From: Dan Ramage <dan at inlet.geol.sc.edu>
>> To: Tom Kralidis <tomkralidis at gmail.com>
>> Cc: "pycsw-devel at lists.osgeo.org" <pycsw-devel at lists.osgeo.org>
>> Subject: Re: [pycsw-devel] Links Question
>> What's the reasoning for not using the Viewer Information string?
>> Dan
>> On 9/22/14 3:06 PM, "Tom Kralidis" <tomkralidis at gmail.com> wrote:
>>> This should be fixed in the upsteam ncISO tools at this point:
>>> https://github.com/ethanrd/threddsIso/issues/2
>>> https://github.com/Unidata/threddsIso/pull/1
>>> This should alleviate this issue for ncISO based outputs.
>>> ..Tom
>>>> Date: Mon, 22 Sep 2014 14:56:48 -0400
>>>> To: "pycsw-devel at lists.osgeo.org" <pycsw-devel at lists.osgeo.org>
>>>> Subject: [pycsw-devel] Links Question
>>>> I've gotten most of my services issues sorted out via ncISO and using
>>>> an xsl
>>>> file that handles the transforms correctly from Thredds endpoints.
>>>> However I still have an entry of "None" with a link that only appears
>>>> in the
>>>> following metadata section:
>>>> <gmd:distributorTransferOptions>
>>>> <gmd:MD_DigitalTransferOptions>
>>>> <gmd:onLine>
>>>> <gmd:CI_OnlineResource>
>>>> <gmd:linkage>
>>>><gmd:URL>http://www.ncdc.noaa.gov/oa/wct/wct-jnlp-beta.php?singlefile=h
>>>>tt
>>>> p:/
>>>>/omgsrv1.meas.ncsu.edu:8080/thredds/dodsC/fmrc/sabgom/SABGOM_Forecast_M
>>>>od
>>>> el_
>>>> Run_Collection_best.ncd</gmd:URL>
>>>> </gmd:linkage>
>>>> <gmd:name>
>>>> <gco:CharacterString>Viewer
>>>> Information</gco:CharacterString>
>>>> </gmd:name>
>>>> <gmd:description>
>>>> <gco:CharacterString>This URL provides an
>>>> NCDC
>>>> climate and weather toolkit view of an OPeNDAP
>>>> resource.</gco:CharacterString>
>>>> </gmd:description>
>>>> <gmd:function>
>>>> <gmd:CI_OnLineFunctionCode
>>>>codeList="http://www.ngdc.noaa.gov/metadata/published/xsd/schema/resour
>>>>ce
>>>> s/C
>>>> odelist/gmxCodelists.xml#CI_PresentationFormCode"
>>>> codeListValue="mapDigital">mapDigital</gmd:CI_OnLineFunctionCode>
>>>> </gmd:function>
>>>> </gmd:CI_OnlineResource>
>>>> </gmd:onLine>
>>>> </gmd:MD_DigitalTransferOptions>
>>>> </gmd:distributorTransferOptions>
>>>> Should this be picked up at all? There is a similar section above it
>>>>as
>>>> well
>>>> that is a gmd:name http. I am not sure if this one is getting handled
>>>> since
>>>> I do have an http entry in the links or if that was from a
>>>>gmd:protocol
>>>> section.
>>>> Dan
More information about the pycsw-devel
