[pycsw-devel] Custom Metadata Profile
Alejandro Mostovoi
ahmostovoi at gmail.com
Fri Feb 20 10:18:21 PST 2015
Thanks Tom!
Slds.
Alejandro.
On 20 February 2015 at 13:51, Tom Kralidis <tomkralidis at gmail.com> wrote:
> Hi Alejandro:
> On Fri, Feb 20, 2015 at 10:10 AM, Alejandro Mostovoi
> <ahmostovoi at gmail.com> wrote:
> > Hi all,
> > I'm using pycsw 1.10 for developing a SDI. That SDI will use a custom
> > metadata profile which inherits from ISO 19115. The custom profile
> doesn't
> > add fields, It's only a subset of ISO 19115.
> > The APISO profile could work? or Should I develop a profile plugin to
> > support that profile?
> The APISO profile will work in this case so no need to develop a
> profile plugin. Developing a profile plugin becomes useful once you
> start extending a metadata model and / or introducing custom
> queryables to the CSW endpoint.
> Hope this helps.
> ..Tom
> > Thanks in advance.
> > Alejandro.
URL: <http://lists.osgeo.org/pipermail/pycsw-devel/attachments/20150220/602e3050/attachment.html>
More information about the pycsw-devel
