[pycsw-devel] metadata editor
Tom Kralidis
tomkralidis at gmail.com
Mon Jul 27 12:00:33 PDT 2015
Thanks Eva: added to docs in master and 1.10 branches.
Thanks
..Tom
On Mon, 27 Jul 2015, Eva Jelínková wrote:
> Date: Mon, 27 Jul 2015 20:27:29 +0200
> From: Eva Jelínková <evka.jelinkova at gmail.com>
> To: Tom Kralidis <tomkralidis at gmail.com>
> Cc: pycsw-devel at lists.osgeo.org
> Subject: Re: [pycsw-devel] metadata editor
> Hi Tom,
> I still have pycsw 1.9 so I haven't seen the thing with -y in
> pycsw-admin.py. My fault... I'll upgrade!
> Adding this to the docs is definitely a good idea.
> Thanks a lot,
> Eva
> 2015-07-27 18:36 GMT+02:00 Tom Kralidis <tomkralidis at gmail.com>:
>> Date: Mon, 27 Jul 2015 17:34:36 +0200
>>> Hello Tom,
>>> thank you very much for your response. We are still at the stage of
>>> research and testing.
>>> We are going to store metadata XMLs in pycsw - it's great that user can
>>> access it easily via QGIS. We've already tested harvesting to CKAN which
>>> we
>>> plan to use as graphical user interface for browsing and searching.
>>> Our workflow is going to be probably like this:
>>> web form => MCF file => pygeometa => XML => pycsw => CKAN
>>> Thanks for Flask recommendation!
>>> I was thinking also about using CKAN as form for creating/editing records
>>> but I found it difficult to get the edited record back to pycsw or create
>>> XML straight from CKAN...
>>> There is one thing in pycsw that I haven't got yet. Maybe you can help me.
>>> I have some testing XMLs that I load to pycsw via pycsw-admin.py:
>>> python /path/to/pycsw-admin.py -c load_records -f /path/to/pycsw.cfg -p
>>> /path/to/xml -r
>> When I update some of that XMLs it is impossible to just reload it because
>>> "Key (identifier)=(xy) already exists". So the easiest way for me (for now
>>> - I have just a few records) is delete all records in DB and than load
>>> them
>>> again.
>> We addressed this in https://github.com/geopython/pycsw/issues/290.
>> Adding a -y flag to pycsw-admin.py will force update (do a pycsw-admin.py
>> -h to
>> see examples). I wonder whether we should add this to the docs (
>> http://docs.pycsw.org/en/latest/administration.html#loading-records) as
>> well?
>> I think the right way would be to use transactions (update) instead of
>>> deleting all the records all the time...
>>> Unfortunately there is not so much information about transactions in
>>> documentation (when I will be able to use transactions correctly I could
>>> add there some notes for people who are novices as I am :D ).
>>> For full update I added tags csw:Transaction and csw:Update to my metadata
>>> XML:
>>> <csw:Transaction ...>
>>> <csw:Update>
>>> <gmd:MD_Metadata ...>
>>> </gmd:MD_Metadata>
>>> </csw:Update>
>>> </csw:Transaction>
>>> and posted it by pycsw-admin.py:
>>> python /path/to/pycsw-admin.py -c post_xml -x /path/to/xml/sample.xml -u
>>> http://myhost/cgi-bin/csw.py
>>> It worked :) but my question is - is there any possibility to do the full
>>> update for whole directory full of XMLs (all with update tags)? According
>>> to the information I found here [1], full update should be able to update
>>> records in DB and also add new ones. I think that maybe we could create
>>> all
>>> XML files as update XMLs and than every time we run post_xml we would have
>>> all records updated. Would it be possible or am I on the completely wrong
>>> way?
>> The underlying functionality of pycsw-admin.py is all scriptable as well,
>> so
>> you could write a script create a csw:Transaction XML as you describe with
>> each XML file in a directory written inline. Having said this,
>> pycsw-admin.py
>> provides these as convenience functions if you are able to run on the
>> command
>> line, and the -y flag will force the update.
>> Hope this helps.
>> ..Tom
>>> Thanks for any advice,
>>> Eva Jelinkova
>>> [1]
>>> http://geopython.github.io/pycsw-workshop/docs/advanced/transactions.html
>>> 2015-07-27 14:41 GMT+02:00 Tom Kralidis <tomkralidis at gmail.com>:
>>>> On Sun, 26 Jul 2015, Eva Jelínková wrote:
>>>> Date: Sun, 26 Jul 2015 23:17:05 +0200
>>>>> To: pycsw-devel at lists.osgeo.org
>>>>> Subject: [pycsw-devel] metadata editor
>>>>> Hi all pycsw people,
>>>>> we are trying to set a catalog service based on pycsw to store the
>>>>> information about the data and services in our company. pycsw works well
>>>> Great to hear this! If you have endpoint(s), feel free to add them /
>>>> have
>>>> them added to our live deployments wiki page [1], which powers our live
>>>> deployments map [2].
>>>> for us, it seems that the only problem is creation of metadata
>>>> records...
>>>>> I
>>>>> have tried GIMED and EUOSME metadata editors but none is good enough for
>>>>> our case. We need just an easy open source web form (ideally python
>>>>> based).
>>>>> It don't have to be valid for all requirements of the INSPIRE directive.
>>>>> We
>>>>> will probably develop one but if there is any similar project you know
>>>>> about, just let me know, please. It would really help us.
>>>>> There are numerous web options out there embedded in applications like
>>>> GeoNode and CKAN, however at the cost of all the associated machinery.
>>>> Having said this, as part of another project I'm involved in, we recently
>>>> released pygeometa [3] which supports creating ISO from a simple
>>>> ConfigParser
>>>> file/object. You could implement a simple Flask [4] based front end to
>>>> provide a form and saving logic, which would create a pygeometa
>>>> metadata object and then serialize to a metadata file as desired. Or,
>>>> even
>>>> better, publish directly to pycsw :)
>>>> ..Tom
>>>> [1] https://github.com/geopython/pycsw/wiki/Live-Deployments
>>>> [2] http://pycsw.org/community/
>>>> [3] https://github.com/geopython/pygeometa
>>>> [4] http://flask.pocoo.org/
More information about the pycsw-devel
