[pycsw-devel] metadata editor
Jachym Cepicky
jachym.cepicky at gmail.com
Mon Jul 27 23:56:24 PDT 2015
Thanks Tom
J
po 27. 7. 2015 v 21:05 odesílatel Tom Kralidis <tomkralidis at gmail.com>
napsal:
> Thanks Eva: added to docs in master and 1.10 branches.
> Thanks
> ..Tom
> On Mon, 27 Jul 2015, Eva Jelínková wrote:
> > Date: Mon, 27 Jul 2015 20:27:29 +0200
> > From: Eva Jelínková <evka.jelinkova at gmail.com>
> > To: Tom Kralidis <tomkralidis at gmail.com>
> > Cc: pycsw-devel at lists.osgeo.org
> > Subject: Re: [pycsw-devel] metadata editor
> > Hi Tom,
> > I still have pycsw 1.9 so I haven't seen the thing with -y in
> > pycsw-admin.py. My fault... I'll upgrade!
> > Adding this to the docs is definitely a good idea.
> > Thanks a lot,
> > Eva
> > 2015-07-27 18:36 GMT+02:00 Tom Kralidis <tomkralidis at gmail.com>:
> >> Date: Mon, 27 Jul 2015 17:34:36 +0200
> >>> Hello Tom,
> >>> thank you very much for your response. We are still at the stage of
> >>> research and testing.
> >>> We are going to store metadata XMLs in pycsw - it's great that user can
> >>> access it easily via QGIS. We've already tested harvesting to CKAN
> which
> >>> we
> >>> plan to use as graphical user interface for browsing and searching.
> >>> Our workflow is going to be probably like this:
> >>> web form => MCF file => pygeometa => XML => pycsw => CKAN
> >>> Thanks for Flask recommendation!
> >>> I was thinking also about using CKAN as form for creating/editing
> records
> >>> but I found it difficult to get the edited record back to pycsw or
> create
> >>> XML straight from CKAN...
> >>> There is one thing in pycsw that I haven't got yet. Maybe you can help
> me.
> >>> I have some testing XMLs that I load to pycsw via pycsw-admin.py:
> >>> python /path/to/pycsw-admin.py -c load_records -f /path/to/pycsw.cfg -p
> >>> /path/to/xml -r
> >> When I update some of that XMLs it is impossible to just reload it
> because
> >>> "Key (identifier)=(xy) already exists". So the easiest way for me (for
> now
> >>> - I have just a few records) is delete all records in DB and than load
> >>> them
> >>> again.
> >> We addressed this in https://github.com/geopython/pycsw/issues/290.
> >> Adding a -y flag to pycsw-admin.py will force update (do a
> pycsw-admin.py
> >> -h to
> >> see examples). I wonder whether we should add this to the docs (
> >> http://docs.pycsw.org/en/latest/administration.html#loading-records) as
> >> well?
> >> I think the right way would be to use transactions (update) instead of
> >>> deleting all the records all the time...
> >>> Unfortunately there is not so much information about transactions in
> >>> documentation (when I will be able to use transactions correctly I
> could
> >>> add there some notes for people who are novices as I am :D ).
> >>> For full update I added tags csw:Transaction and csw:Update to my
> metadata
> >>> XML:
> >>> <csw:Transaction ...>
> >>> <csw:Update>
> >>> <gmd:MD_Metadata ...>
> >>> </gmd:MD_Metadata>
> >>> </csw:Update>
> >>> </csw:Transaction>
> >>> and posted it by pycsw-admin.py:
> >>> python /path/to/pycsw-admin.py -c post_xml -x /path/to/xml/sample.xml
> -u
> >>> http://myhost/cgi-bin/csw.py
> >>> It worked :) but my question is - is there any possibility to do the
> full
> >>> update for whole directory full of XMLs (all with update tags)?
> According
> >>> to the information I found here [1], full update should be able to
> update
> >>> records in DB and also add new ones. I think that maybe we could create
> >>> all
> >>> XML files as update XMLs and than every time we run post_xml we would
> have
> >>> all records updated. Would it be possible or am I on the completely
> wrong
> >>> way?
> >> The underlying functionality of pycsw-admin.py is all scriptable as
> well,
> >> so
> >> you could write a script create a csw:Transaction XML as you describe
> with
> >> each XML file in a directory written inline. Having said this,
> >> pycsw-admin.py
> >> provides these as convenience functions if you are able to run on the
> >> command
> >> line, and the -y flag will force the update.
> >> Hope this helps.
> >> ..Tom
> >>> Thanks for any advice,
> >>> Eva Jelinkova
> >>> [1]
> http://geopython.github.io/pycsw-workshop/docs/advanced/transactions.html
> >>> 2015-07-27 14:41 GMT+02:00 Tom Kralidis <tomkralidis at gmail.com>:
> >>>> On Sun, 26 Jul 2015, Eva Jelínková wrote:
> >>>> Date: Sun, 26 Jul 2015 23:17:05 +0200
> >>>>> To: pycsw-devel at lists.osgeo.org
> >>>>> Subject: [pycsw-devel] metadata editor
> >>>>> Hi all pycsw people,
> >>>>> we are trying to set a catalog service based on pycsw to store the
> >>>>> information about the data and services in our company. pycsw works
> well
> >>>> Great to hear this! If you have endpoint(s), feel free to add them /
> >>>> have
> >>>> them added to our live deployments wiki page [1], which powers our
> live
> >>>> deployments map [2].
> >>>> for us, it seems that the only problem is creation of metadata
> >>>> records...
> >>>>> I
> >>>>> have tried GIMED and EUOSME metadata editors but none is good enough
> for
> >>>>> our case. We need just an easy open source web form (ideally python
> >>>>> based).
> >>>>> It don't have to be valid for all requirements of the INSPIRE
> directive.
> >>>>> We
> >>>>> will probably develop one but if there is any similar project you
> know
> >>>>> about, just let me know, please. It would really help us.
> >>>>> There are numerous web options out there embedded in applications
> like
> >>>> GeoNode and CKAN, however at the cost of all the associated machinery.
> >>>> Having said this, as part of another project I'm involved in, we
> recently
> >>>> released pygeometa [3] which supports creating ISO from a simple
> >>>> ConfigParser
> >>>> file/object. You could implement a simple Flask [4] based front end
> to
> >>>> provide a form and saving logic, which would create a pygeometa
> >>>> metadata object and then serialize to a metadata file as desired. Or,
> >>>> even
> >>>> better, publish directly to pycsw :)
> >>>> ..Tom
> >>>> [1] https://github.com/geopython/pycsw/wiki/Live-Deployments
> >>>> [2] http://pycsw.org/community/
> >>>> [3] https://github.com/geopython/pygeometa
> >>>> [4] http://flask.pocoo.org/
> pycsw-devel mailing list
> http://lists.osgeo.org/mailman/listinfo/pycsw-devel
URL: <http://lists.osgeo.org/pipermail/pycsw-devel/attachments/20150728/f04afdd1/attachment.html>
More information about the pycsw-devel
