[pycsw-devel] Making Harvesting in a dedicated server PyCSW from catalogs CSW in GeoNode servers
Tom Kralidis tomkralidis at gmail.com
Mon Jun 29 17:26:14 PDT 2015
Hi Davi: FYI I was able to track this down.  For some reason, some
records are malformed from demo.geonode.org:
http://demo.geonode.org/catalogue/csw?service=CSW&version=2.0.2&request=GetRecords&typenames=csw:Record&elementsetname=full&outputschema=http://www.isotc211.org/2005/gmd&resulttype=results&maxrecords=5
I've updated master branch to catch this gracefully and skip
harvesting if this is the case [1].  If you can test master branch and
verify, I will also backport to 1.10 branch.
Thanks
..Tom
[1] https://github.com/geopython/pycsw/commit/64876838e39ccdaac59172ffc01e026a6ad4e0a1
On Tue, Jun 23, 2015 at 12:57 PM, Davi Custodio <davicustodio at gmail.com> wrote:
> Tom, I was able to upgrade to version 1.10.1, but the problem continues. I
> realized that I can point to any CSW that the error is the same. Below the
> error I get to the point to http://demo.geonode.org/catalogue/csw
> <! - Pycsw 1.10.1 ->
> <Ows: ExceptionReport xmlns: dc = "http://purl.org/dc/elements/1.1/" xmlns:
> inspire_common = "http://inspire.ec.europa.eu/schemas/common/1.0" xmlns:
> atom = "http://www.w3.org/2005/Atom" xmlns: xs =
> "http://www.w3.org/2001/XMLSchema" xmlns: dct = "http://purl.org/dc/ terms /
> "xmlns: ows =" http://www.opengis.net/ows "xmlns: apiso ="
> http://www.opengis.net/cat/csw/apiso/1.0 "xmlns: gml =" http:
> //www.opengis.net/gml "xmlns: diff ="
> http://gcmd.gsfc.nasa.gov/Aboutus/xml/dif/ "xmlns: xlink ="
> http://www.w3.org/1999 / xlink "xmlns: gco ="
> http://www.isotc211.org/2005/gco "xmlns: gmd ="
> http://www.isotc211.org/2005/gmd "xmlns: rdf =" http: //
> www.w3.org/1999/02/22-rdf-syntax-ns# "xmlns: srv ="
> http://www.isotc211.org/2005/srv "xmlns: ogc =" http: //www.opengis .net /
> ogc "xmlns: FGDC =" http://www.opengis.net/cat/csw/csdgm "xmlns: inspire_ds
> =" http://inspire.ec.europa.eu/schemas/inspire_ds/1.0 "xmlns : csw =
> "http://www.opengis.net/cat/csw/2.0.2" xmlns: xsi =
> "http://www.w3.org/2001/XMLSchema-instance" xmlns: the = "http:
> //a9.com/-/spec/opensearch/1.1/ "xmlns: soapenv ="
> http://www.w3.org/2003/05/soap-envelope "xmlns: sitemap =" http:
> //www.sitemaps .org / schemas / sitemap / 0.9 "language =" en-US "version ="
> 1.2.0 "xsi: schemaLocation =" http://www.opengis.net/ows
> http://schemas.opengis.net/ows /1.0.0/owsExceptionReport.xsd"><ows:Exception
> ExceptionCode = "NoApplicableCode" locator = "source"> <ows: ExceptionText>
> Harvest (insert) failed: ERROR: null value in column "identifier" violates
> not-null constraint
> DETAIL: Failing row contains (null, csw: Record,
> http://www.opengis.net/cat/csw/2.0.2, local, 2015-06-23T13: 53: 57Z & lt;
> ows: ExceptionReport xmlns: dc = "http://purl.org/dc/elements/1.1/" ...
> Missing keyword: service, null, null, null, null, null, null, null, null,
> null, null, null, null, null, null, null, null, null, null, null, null,
> null, null, null, null, null, null, http://demo.geonode.org/catalogue/csw,
> null, null, null, null, null, null, null, null, null, null, 'keyword': 2
> 'miss': 1 'servic': 3, null).
> . </ Ows: ExceptionText> </ ows: Exception> </ ows: ExceptionReport>
> In the apache logs also I found nothing. You suspect something?
> thanks
> On Mon, Jun 22, 2015 at 12:24 PM, Angelos Tzotsos <gcpp.kalxas at gmail.com>
> wrote:
>> pycsw 1.10.1 has just been pushed in ubuntugis unstable. It will be
>> available in ~2h
>> On 06/22/2015 05:30 PM, Davi Custodio wrote:
>> Hi Tom.
>> I do this having trouble accessing external urls in my server. Fix, and
>> did
>> the test again pointing to the xml you stated:
>> https://github.com/geopython/pycsw/blob/master/tests/suites/harvesting/post/Harvest-csw-run1.xml
>> .. But the error was the same:
>> pycsw-admin.py -c -u post_xml http: //localhost/pycsw/csw.py -x / var /
>> www
>> / html / pycsw / bin / request .xml
>> Initializing static context
>> Executing HTTP POST request /var/www/html/pycsw/bin/request.xml on server
>> <? Xml version = "1.0" encoding = "UTF-8" standalone = "no"?>
>> <! - Pycsw 1.10.0 ->
>> xmlns:
>> atom = "http://www.w3.org/2005/Atom" xmlns: xs = "
>> http://www.opengis.net/cat/csw/apiso/1.0 "xmlns: gml =" http: //
>> inspire_ds
>> =" http://inspire.ec.europa.eu/schemas/inspire_ds/1.0 "xmlns : csw = "
>> http://www.opengis.net/cat/csw/2.0.2" xmlns: xsi = "
>> http://www.w3.org/2001/XMLSchema-instance" xmlns: the = "http: //
>> =" 1.2.0 "xsi: schemaLocation =" http://www.opengis.net/ows
>> /1.0.0/owsExceptionReport.xsd"><ows:Exception ExceptionCode =
>> "NoApplicableCode" locator = "source"> <ows: ExceptionText> Harvest
>> not-null
>> constraint
>> http://www.opengis.net/cat/csw/2.0.2, local, 2015-06-22T11: 23: 47Z & lt;
>> Done
>> Attached, I am sending the response for
>> http://aguai.cnpm.embrapa.br/catalogue/csw?request=GetRecords&service=CSW&version=2.0.2&resultType=results&outputSchema=http://www.isotc211.org/2005/gmd&typeNames=csw:Record&elementSetName=summary&maxrecords=1000
>> in which you suggested.
>> I am still using the 1.10.0 version. Could this being resolved by
>> upgrading
>> to 1.10.1? I'm using an Ubuntu 4.14 server. I tried to update the pycsw
>> using apt-get update and then apt-get upgrade, but the pycsw remained in
>> version 1.10.0. How do I upgrade using the Ubuntu packages?
>> Thanks
>> On Fri, Jun 19, 2015 at 4:28 PM, Tom Kralidis <tomkralidis at gmail.com>
>> wrote:
>> Hi Davi: thanks for moving this discussion here from geonode-users.
>> Comments interleaved.
>> On Fri, Jun 19, 2015 at 3:09 PM, Davi Custodio <davicustodio at gmail.com>
>> wrote:
>> Hello. I have a scenario consists of 8 GeoNode servers with their
>> respective
>> PyCSW assets.
>> To test, Getrecords use as:
>> http://localhost/catalogue/csw?request=GetRecords&service=CSW&version=2.0.2&resultType=results&outputSchema=http://www.isotc211.org/2005/gmd&typeNames=csw:Record&elementSetName=summary
>> and receive the corresponding xml correctly.
>> You can also configure the harvest within the Geonetwork using:
>> http: // localhost / catalog / csw version = 2.0.2 & request =
>> GetCapabilities & service = CSW
>> and also the harvest runs properly.
>> I created a dedicated server with the default installation of PyCSW
>> 1.10.0,
>> and I'm trying to get this server collect all the metadata records of 8
>> servers GeoNode.
>> My intention is to have a PyCSW to gather all the metadata of my
>> organization. I'm avoiding using "federatedcatalogues" because I do not
>> want
>> the user who will rep csw need to specify additional parameters.
>> In a first test, I used the command:
>> pycsw-admin.py -c -u post_xml http: -x //localhost/pycsw/csw.py
>> where request.xml =
>> <? Xml version = "1.0" encoding = "UTF-8"?>
>> <Harvest xmlns = "http://www.opengis.net/cat/csw/2.0.2" xmlns: ogc =
>> "http://www.opengis.net/ogc" xmlns: gmd = "http: // www .isotc211.org /
>> 2005
>> / gmd "xmlns: ows =" http://www.opengis.net/ows "xmlns: xsd
>> ="http://www.w3.org/2001/XMLSchema "xmlns: dc ="
>> http://purl.org/dc/elements/1.1/ "xmlns: dct ="
>> http://purl.org/dc/terms/
>> "xmlns: gml =" http://www.opengis.net/gml " xmlns: xsi =
>> "http://www.w3.org/2001/XMLSchema-instance" xsi: schemaLocation =
>> "http://www.opengis.net/cat/csw/2.0.2 http: //schemas.opengis .net /
>> csw /
>> 2.0.2 / CSW-publication.xsd "service =" CSW "version =" 2.0.2 ">
>>   <Source>http://demo.geonode.org//catalogue/csw </ Source>
>>   <ResourceType> http://www.opengis.net/cat/csw/2.0.2 </ ResourceType>
>>   <ResourceFormat> application / xml </ ResourceFormat>
>> </ Harvest>
>> pointing to http://demo.geonode.org//catalogue/csw ..
>> I get the following error:
>> Traceback (most recent call last):
>>    File "/usr/bin/pycsw-admin.py", line 246, in <module>
>>      print admin.post_xml (CSW_URL, XML, TIMEOUT)
>>    File "/usr/lib/python2.7/dist-packages/pycsw/admin.py", line 495, in
>> post_xml
>>      raise RuntimeError (err)
>> RuntimeError: timed out
>> I'm not getting any timeout when running here (using 1.10.1 -- any
>> chance you can upgrade your single non-GeoNode pycsw instance to
>> 1.10.1?) using the Harvest XML request like
>> but substituting the Source with http://demo.geonode.org/catalogue/csw
>> pycsw harvests 36 records (1 for the service and 35 metadata records).
>> Are you able to see http://demo.geonode.org/catalogue/csw from the box
>> on which you are running your harvests from?
>> when I point to one of my GeoNode-PyCSW servers using request.xml as:
>> 2005
>> csw /
>>   <Source> http://aguai.cnpm.embrapa.br/catalogue/csw </ Source>
>> </ Harvest>
>> pointing to my server: http://aguai.cnpm.embrapa.br/catalogue/csw
>> I get the error:
>> xmlns:
>> terms /
>> ="http://gcmd.gsfc.nasa.gov/Aboutus/xml/dif/ "xmlns: xlink ="
>> //www.w3.org/1999/02/22-rdf-syntax-ns# "xmlns: srv ="
>> .net /
>> inspire_ds
>> ="http://inspire.ec.europa.eu/schemas/inspire_ds/1.0 "xmlns : csw =
>> "version ="
>> http://www.opengis.net/owshttp://schemas.opengis.net/ows
>> (insert)
>> failed: ERROR: null value in column "identifier" violates not-null
>> constraint
>> http://www.opengis.net/cat/csw/2.0.2, local, 2015-06-19T15: 19: 28Z &
>> lt;
>> http://aguai.cnpm.embrapa.br/catalogue/csw, null, null, null, null,
>> null,
>> null, null, null, null, null, 'keyword': 2 'miss': 1' servic '3, null).
>> Done
>> Can anyone help me explaining how to best implement it? And because of
>> errors?
>> It looks like one of the layers in your pycsw serving GeoNode CSW does
>> not have an identifier?  Can you turn on pycsw logging from your
>> single pycsw to DEBUG and run the harvest again?  There might be
>> valuable information in the log that can help.  Feel free to send me
>> the log output offline.
>> As well, wow many records does
>> http://aguai.cnpm.embrapa.br/catalogue/csw have?  Might be valuable to
>> do a full GetRecords request, i.e.:
>> http://aguai.cnpm.embrapa.br/catalogue/csw?request=GetRecords&service=CSW&version=2.0.2&resultType=results&outputSchema=http://www.isotc211.org/2005/gmd&typeNames=csw:Record&elementSetName=summary&maxrecords=FOO
>> to inspect the actual CSW output that pycsw is trying to harvest.
>> Feel free to send me the result offline.
>> Davi de O. Custódio
>> pycsw-devel mailing list
>> pycsw-devel at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/pycsw-devel
>> Angelos Tzotsos
>> Remote Sensing Laboratory
>> National Technical University of Athens
>> http://users.ntua.gr/tzotsos
> Davi de O. Custódio
More information about the pycsw-devel mailing list
