[pycsw-devel] CSW search by other fields
Tom Kralidis tomkralidis at gmail.com
Tue Sep 29 19:58:36 PDT 2015
Hi Juan:`
On Tue, Sep 29, 2015 at 3:54 PM, Juan Rapoport
<juanrapoport at suremptec.com.ar> wrote:
> Hi,
> Is it possible to configure which are the queryable fields for the
> GetRecords requests?
Can you provide more context or use case(s)?  Is the goal here solely
to extend queryables against additional columns from a custom
database?  Do these queryables need to be provided in the CSW response
(i.e. returnables)?  Can you provide some examples of what sample
queries could look like?
We've had similar discussions before, and implementation/enhancement
options range from allowing an extensible queryables approach via
configuration, to custom non-standard CSW application profiles (which
I'd tend to avoid unless absolutely required).
Cheers
..Tom
> Thanks
> Juan Rapoport
> SUR Emprendimientos Tecnológicos
More information about the pycsw-devel mailing list
