[pycsw-devel] Federated Search question
Alejandro Mostovoi
ahmostovoi at gmail.com
Fri Apr 1 12:31:20 PDT 2016
thanks for fix it. We'll wait for the release of pycsw 1.10.4.
Cheers.
Alejandro
On Fri, 1 Apr 2016 at 16:17 Tom Kralidis <tomkralidis at gmail.com> wrote:
> On Wed, Mar 30, 2016 at 3:54 PM, Tom Kralidis <tomkralidis at gmail.com>
> wrote:
> > On Wed, 30 Mar 2016, Alejandro Mostovoi wrote:
> >> Date: Wed, 30 Mar 2016 19:24:58 +0000
> >> From: Alejandro Mostovoi <ahmostovoi at gmail.com>
> >> To: "pycsw-devel at lists.osgeo.org" <pycsw-devel at lists.osgeo.org>
> >> Subject: [pycsw-devel] Federated Search question
> >> Hi All,
> >> I'm trying to make a distributed search against other CSW server. Both
> >> servers use ISO 19139 metadata standard.
> >> I'm performing a GetRecords operation using this xml:
> >> <csw:GetRecords xmlns:csw="http://www.opengis.net/cat/csw/2.0.2"
> >> xmlns:ogc="
> >> http://www.opengis.net/ogc" xmlns:gml="http://www.opengis.net/gml"
> >> service="CSW" version="2.0.2" resultType="results"
> >> *outputSchema="http://www.isotc211.org/2005/gmd
> >> <http://www.isotc211.org/2005/gmd>"*> <csw:DistributedSearch
> >> hopCount="2"/>
> >> <csw:Query typeNames="gmd:MD_Metadata">
> >> <csw:ElementSetName>full</csw:ElementSetName>
> >> </csw:Query>
> >> </csw:GetRecords>
> >> The response should have 2 records, but it has only 1 record and a
> comment
> >> which says: <!-- 1 result from <csw server url> --> and nothing else.
> >> I made another test, changing the outputSchema to
> >> *outputSchema="http://www.opengis.net/cat/csw/2.0.2*
> >> and the response has the 2 records, but with a different schema.
> >> I need to get the 2 records with the *gmd* schema. What I'm doing wrong?
> >> The pycsw version is 1.10.3, on Ubuntu Server 14.04 64-bit.
> >> Thanks in advance.
> >> Alejandro
> > My first guess is that the CSW that you are federated against is
> refusing to
> > transform
> > all metadata records to ISO. Or that pycsw is not telling it to do so
> for
> > some reason.
> > What happens when you apply the following queries directly against the
> > federated CSW:
> > query 1:
> > xmlns:gmd="http://www.isotc211.org/gmd"
> > outputSchema="http://www.isotc211.org/2005/gmd">
> > </csw:Query>
> > </csw:GetRecords>
> > query 2:
> > service="CSW" version="2.0.2" resultType="results">
> > <csw:Query typeNames="csw:Record">
> > </csw:Query>
> > </csw:GetRecords>
> > If the federated CSW is returning 2 records in both cases, then there is
> a
> > moving part in pycsw's
> > distributed search. In this case, if you turn on logging (level=DEBUG),
> run
> > only the two requests
> > and send the logging output (offline) that would be great. If there's
> any
> > chance of sending the federated
> > CSW in question (offline) I can try to reproduce and debug deeper
> locally.
> Alejandro: digging deeper, the issue was rooted in an OWSLib bug (now
> fixed).
> See [1] for a full explanation. In addition, I ended up making
> safeguard changes
> within pycsw itself in the case of an older OWSLib version.
> At this point, OWSLib 0.11.0 has been released and pycsw 1.10.3 will work
> expected given this upgrade. As well, pycsw 1.10.4 (in the next week or
> so)
> will be released, which will cover the fix whether OWSLib has been upgraded
> to 0.11.0 or not.
> Thanks very much for reporting!
> Cheers
> ..Tom
> [1] https://github.com/geopython/pycsw/issues/413
URL: <http://lists.osgeo.org/pipermail/pycsw-devel/attachments/20160401/5f4c3586/attachment.html>
More information about the pycsw-devel
