[pycsw-devel] can't run tester application
Margherita Di Leo
diregola at gmail.com
Fri Jan 15 01:23:34 PST 2016
Replying to myself. I had to specify the port:
http://localhost:8000/pycsw/tester/index.html
Sorry for the noise
On Thu, Jan 14, 2016 at 12:22 PM, Margherita Di Leo <diregola at gmail.com>
wrote:
> Hi,
> I hope this is the right place to put a user question, even if it's -devel
> mailing list.. if I'm in the wrong place please address me.
> I installed pycsw on CentOS 7, I was trying production installation, thus
> I installed it under /var/www/
> I wanted to try testing. I cannot reproduce the tester application
> described here
> https://geopython.github.io/pycsw-workshop/docs/intro/intro-exercises.html
> because under http://localhost/pycsw/tester/index.html I get Forbidden
> You don't have permission to access /pycsw/tester/index.html on this
> server. I guess it must be some Apache settings?
> I have also tried to run
> sudo python run_tests.py -u http://localhost:8000/
> but it gives me:
> Running tests against http://localhost:8000/
> Testing configuration suites/apiso-inspire/default.cfg
> test suites/apiso-inspire/get/requests.txt:GetCapabilities
> Traceback (most recent call last):
> File "run_tests.py", line 289, in <module>
> result = err.read()
> AttributeError: 'URLError' object has no attribute 'read'
> Any help appreciated.
> Thanks
> Margherita Di Leo
Margherita Di Leo
URL: <http://lists.osgeo.org/pipermail/pycsw-devel/attachments/20160115/4b488c64/attachment.html>
More information about the pycsw-devel
