[pycsw-devel] can't run tester application
Angelos Tzotsos gcpp.kalxas at gmail.com
Fri Jan 15 04:49:45 PST 2016
Hi Madi,
Thank you for posting and sorry we were not fast enough.
Please let us know if you have any other issues.
Best,
Angelos
On 01/15/2016 11:23 AM, Margherita Di Leo wrote:
> Replying to myself. I had to specify the port:
> http://localhost:8000/pycsw/tester/index.html
> Sorry for the noise
> On Thu, Jan 14, 2016 at 12:22 PM, Margherita Di Leo <diregola at gmail.com>
> wrote:
>> Hi,
>> I hope this is the right place to put a user question, even if it's -devel
>> mailing list.. if I'm in the wrong place please address me.
>> I installed pycsw on CentOS 7, I was trying production installation, thus
>> I installed it under /var/www/
>> I wanted to try testing. I cannot reproduce the tester application
>> described here
>> https://geopython.github.io/pycsw-workshop/docs/intro/intro-exercises.html
>> because under http://localhost/pycsw/tester/index.html I get Forbidden
>> You don't have permission to access /pycsw/tester/index.html on this
>> server. I guess it must be some Apache settings?
>> I have also tried to run
>> sudo python run_tests.py -u http://localhost:8000/
>> but it gives me:
>> Running tests against http://localhost:8000/
>> Testing configuration suites/apiso-inspire/default.cfg
>>   test suites/apiso-inspire/get/requests.txt:GetCapabilities
>> Traceback (most recent call last):
>>    File "run_tests.py", line 289, in <module>
>>      result = err.read()
>> AttributeError: 'URLError' object has no attribute 'read'
>> Any help appreciated.
>> Thanks
>> Margherita Di Leo
> pycsw-devel mailing list
> pycsw-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pycsw-devel
Angelos Tzotsos, PhD
OSGeo Charter Member
http://users.ntua.gr/tzotsos
URL: <http://lists.osgeo.org/pipermail/pycsw-devel/attachments/20160115/0f3acf74/attachment.html>
More information about the pycsw-devel mailing list
