[pycsw-devel] Use extra_columns in pycsw-admin setup_db
Thomas Mistelbauer Thomas.Mistelbauer at eodc.eu
Wed Jun 21 04:12:26 PDT 2017
Hi Angelos,
this looks indeed very promising for us! Thank you for this tip!
Best regards,
Thomas
On Sun, 2017-06-18 at 14:44 +0300, Angelos Tzotsos wrote:
> Hi Thomas,
> I just opened a ticket for the OGC OpenSearch EO extension, that
> would
> probably bring into pycsw all the extra fields that you require.
> https://github.com/geopython/pycsw/issues/538
> Regards,
> Angelos
> On 06/15/2017 04:26 AM, Tom Kralidis wrote:
> > Hi Thomas:
> > On Fri, Jun 9, 2017 at 3:29 AM, Thomas Mistelbauer
> > <Thomas.Mistelbauer at eodc.eu> wrote:
> > > Dear pycsw developers,
> > > I am currently setting up a pycsw server for the Earth
> > > Observation Data
> > > Centre (https://pycsw.eodc.eu/), where we mainly host Copernicus
> > > Sentinel
> > > data.
> > Great to see this! Please feel free to add this deployment to our
> > Live
> > Deployments
> > wiki (https://github.com/geopython/pycsw/wiki/Live-Deployments)
> > which powers
> > our map at http://pycsw.org/community
> > > So far, I managed to set up the server using the default metadata
> > > profiles,
> > > however, in the next step, we need to add additional metadata
> > > elements (e.g.
> > > cloud-coverage), that are not covered by both the standard
> > > profiles and the
> > > database table columns.
> > > I understand that I have to create a custom profile, however I
> > > don't really
> > > know what is the best way to extend the database table. I see
> > > that it is
> > > possible pass 'extra_columns' in setup_db, however, this argument
> > > is not
> > > used in the admin.setup_db in pycsw-admin.py. If I run setup_py
> > > in admin.py
> > > "manually", I lose the comfort of the config file. I know that
> > > this is no
> > > big deal, however, I would find it very convenient if it would be
> > > possible
> > > to set 'extra_columns' int the repository section of the config
> > > file, so
> > > that these columns are automatically created when pycsw-admin -c
> > > setup_db is
> > > executed.
> > Very good point; setup_db's extra_columns argument was implemented
> > primarily for use by composable workflows (see how CKAN uses it in
> > https://github.com/ckan/ckanext-spatial/blob/master/bin/ckan_pycsw.
> > py#L17)
> > > Is there any reason why this is not the case already, or am I
> > > missing
> > > something completely, and there is a better way to implement
> > > additional
> > > columns? If not, then I would be happy to work on that :-)
> > Can you open a GitHub issue for this enhancement? I think having
> > configurable columns in the pycsw config is a great idea and user
> > friendly.  Thanks for this feedback!
> > ..Tom
> > > Thank you for your help and time! :-)
> > > Best regards,
> > > Thomas
> > > _______________________________________________
> > > pycsw-devel mailing list
> > > pycsw-devel at lists.osgeo.org
> > > https://lists.osgeo.org/mailman/listinfo/pycsw-devel
More information about the pycsw-devel mailing list
