[pycsw-devel] Use extra_columns in pycsw-admin setup_db
Angelos Tzotsos gcpp.kalxas at gmail.com
Sun Jun 18 04:44:35 PDT 2017
Hi Thomas,
I just opened a ticket for the OGC OpenSearch EO extension, that would
probably bring into pycsw all the extra fields that you require.
https://github.com/geopython/pycsw/issues/538
Regards,
Angelos
On 06/15/2017 04:26 AM, Tom Kralidis wrote:
> Hi Thomas:
> On Fri, Jun 9, 2017 at 3:29 AM, Thomas Mistelbauer
> <Thomas.Mistelbauer at eodc.eu> wrote:
>> Dear pycsw developers,
>> I am currently setting up a pycsw server for the Earth Observation Data
>> Centre (https://pycsw.eodc.eu/), where we mainly host Copernicus Sentinel
>> data.
> Great to see this! Please feel free to add this deployment to our Live
> Deployments
> wiki (https://github.com/geopython/pycsw/wiki/Live-Deployments) which powers
> our map at http://pycsw.org/community
>> So far, I managed to set up the server using the default metadata profiles,
>> however, in the next step, we need to add additional metadata elements (e.g.
>> cloud-coverage), that are not covered by both the standard profiles and the
>> database table columns.
>> I understand that I have to create a custom profile, however I don't really
>> know what is the best way to extend the database table. I see that it is
>> possible pass 'extra_columns' in setup_db, however, this argument is not
>> used in the admin.setup_db in pycsw-admin.py. If I run setup_py in admin.py
>> "manually", I lose the comfort of the config file. I know that this is no
>> big deal, however, I would find it very convenient if it would be possible
>> to set 'extra_columns' int the repository section of the config file, so
>> that these columns are automatically created when pycsw-admin -c setup_db is
>> executed.
> Very good point; setup_db's extra_columns argument was implemented
> primarily for use by composable workflows (see how CKAN uses it in
> https://github.com/ckan/ckanext-spatial/blob/master/bin/ckan_pycsw.py#L17)
>> Is there any reason why this is not the case already, or am I missing
>> something completely, and there is a better way to implement additional
>> columns? If not, then I would be happy to work on that :-)
> Can you open a GitHub issue for this enhancement? I think having
> configurable columns in the pycsw config is a great idea and user
> friendly.  Thanks for this feedback!
> ..Tom
>> Thank you for your help and time! :-)
>> Best regards,
>> Thomas
>> pycsw-devel mailing list
>> pycsw-devel at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/pycsw-devel
Angelos Tzotsos, PhD
Charter Member
Open Source Geospatial Foundation
http://users.ntua.gr/tzotsos
More information about the pycsw-devel mailing list
