[pycsw-devel] Use extra_columns in pycsw-admin setup_db
Tom Kralidis
tomkralidis at gmail.com
Wed Jun 14 18:26:57 PDT 2017
Hi Thomas:
On Fri, Jun 9, 2017 at 3:29 AM, Thomas Mistelbauer
<Thomas.Mistelbauer at eodc.eu> wrote:
> Dear pycsw developers,
> I am currently setting up a pycsw server for the Earth Observation Data
> Centre (https://pycsw.eodc.eu/), where we mainly host Copernicus Sentinel
> data.
Great to see this! Please feel free to add this deployment to our Live
Deployments
wiki (https://github.com/geopython/pycsw/wiki/Live-Deployments) which powers
our map at http://pycsw.org/community
> So far, I managed to set up the server using the default metadata profiles,
> however, in the next step, we need to add additional metadata elements (e.g.
> cloud-coverage), that are not covered by both the standard profiles and the
> database table columns.
> I understand that I have to create a custom profile, however I don't really
> know what is the best way to extend the database table. I see that it is
> possible pass 'extra_columns' in setup_db, however, this argument is not
> used in the admin.setup_db in pycsw-admin.py. If I run setup_py in admin.py
> "manually", I lose the comfort of the config file. I know that this is no
> big deal, however, I would find it very convenient if it would be possible
> to set 'extra_columns' int the repository section of the config file, so
> that these columns are automatically created when pycsw-admin -c setup_db is
> executed.
Very good point; setup_db's extra_columns argument was implemented
primarily for use by composable workflows (see how CKAN uses it in
https://github.com/ckan/ckanext-spatial/blob/master/bin/ckan_pycsw.py#L17)
> Is there any reason why this is not the case already, or am I missing
> something completely, and there is a better way to implement additional
> columns? If not, then I would be happy to work on that :-)
Can you open a GitHub issue for this enhancement? I think having
configurable columns in the pycsw config is a great idea and user
friendly. Thanks for this feedback!
..Tom
> Thank you for your help and time! :-)
> Best regards,
> Thomas
> pycsw-devel mailing list
> pycsw-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/pycsw-devel
More information about the pycsw-devel
