[pycsw-devel] Running on Windows
Tom Kralidis tom.kralidis at gmail.com
Sun Nov 18 05:53:50 PST 2018
Hi Tim:
On Sun, Nov 18, 2018 at 6:34 AM Tim Wanner <tim_wanner at web.de> wrote:
> Hello Mailing List,
> this might be a 'beginner' question, but I couldn’t find a right description browsing the web and wanted to get this right in my Thesis.
> As the pycsw doc tell’s you’ve got to change line 1 of csw.py into : #!/python27/python -u, bevor installation of pycsw on windows and running it on there.
> Is this pointing to a UNIX (‚Ubuntu‘) directory somewhere external based to config the CGI handler and not to the Python version installed on the local windows computer ? (Win directory should be C:/python27/python.exe)
As per http://docs.pycsw.org/en/stable/installation.html#running-on-windows ,
the example assumes you have Python in \Python27\python .  The drive letter
would be required if you are running if Python and your Python CGI script are
on different paths.  Also note the -u flag for Windows environments
(https://docs.python.org/3.3/using/cmdline.html#cmdoption-u)
Having said this, have you considered running Python on mod_wsgi instead
of CGI?  Many/most Python apps benefit from using mod_wsgi as a long
running process for performance.
Hope this helps.
..Tom
> Or is this just a expression form where under windows apache searches for the python dir. self-sufficient where python is stored for running the CGI Wrapper ?
> I would be pleased about a short background explanation.
> Thanks for your response
> Best Regards
> Tim
> pycsw-devel mailing list
> pycsw-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/pycsw-devel
More information about the pycsw-devel mailing list
